TRX1 and browse objects
keyhole
Germany
maybe someone can help...
when i do a limit search i find many channels including dmr channels which will decoded. then i store the channels as a conventional channel.
when i go now to "browse objects" and want to listening to the channels i hear nothing! even i ticked "dmr" on a dmr channel. also nothing on a fm channel.
when i use "scan" then i can listen to the stored frequencies...so what´s the reason why i don´t hear anything when i manually browse the objects??
VE3SCP
Ontario
When you select the object you want to listen too, hit the "SEL" button. You should now be able to hear it.
VE3SCP
Ontario
You are welcome. I ran into the same issue. It's documented in the manual on page 48.
