ProScan: Trying to setup sds200 on proscan over the internet
bravo14
Polk County FL
I was looking around online and figure out how to setup pro scan and when I'm not home I can control the sds200. I found this video and got the sds to scan on the screen no audio at all when I did the video part 1. Part 2 is useless since I am using a motorola router. I'm running ethernet to the router. I haven't no luck on setting up scanner to go online or get audio.
ProScan
Software Provider
Ontario, Calif.
Work on the audio problem first. Do you have audio on the server side? Go to the Audio Control tab then select the sub-tab. See if the audio meter is moving. If not then click the URL Setup button and see if the audio bytes are incrementing.
bravo14
Polk County FL
I have looked on each sub-tab recorders to Audio Scope see if any movement. Just a flat line.
ProScan
Software Provider
Ontario, Calif.
I went to the Mcafee and firewall and added to the mcafee and firewall click to allow. I see the audio bar movement and I click the loop and hear aduio.
The next step is getting the web server to be seen from the outside. I'm assuming the web server can be seen from the inside.
You want to setup a router port forwarding rule. I would google search -> [your router make and model] port forwarding rule. After the port forwarding rule is added, go to Open Port Check Tool -- Verify Port Forwarding on Your Router to test that the port is open. The server needs to be running for this test.
bravo14
Polk County FL
Not sure if this is correct
ProScan
Software Provider
Ontario, Calif.
Ok. I put that back to 0.0.0.0 What is the next step?
Use canyouseeme.org to test if the Port Forwarding is setup correctly and the server can be seen from the outside. The server needs to be running for this test.
The screenshot is of the RSOIP audio. Are you using the Web Server, or RSOIP server feature, or both?
bravo14
Polk County FL
I'm not using neither. I just took a screen shot of it. Where do I put my ip address in? in the 0.0.0.0? Was thinking using the web server
ProScan
Software Provider
Ontario, Calif.
I thought you were trying to get the Web Server working. Is that correct or not?
If you're not setting up the web server then you don't need to do anything with the router Port Forwarding.
bravo14
Polk County FL
I was trying to get the web sever working where I can listen outside of the home and control the feed.
