Hey all, I've got two scanners running off one antenna with a multicoupler. Then each scanner is plugged into my PC via individual USB sound cards to feed two separate Broadcastify feeds. One feed is running through ProScan, the second is using ScannerCast. When listening to the feed running on ProScan, I can hear the second feed very quiet in the background. When listening to the other one, I can't hear any background noise. Both scanners are connected to the same kind of USB sounds card and plugged into the computer right next to each other. Any idea what might cause this "bleed through" of one feed into the other? Thanks!
