Two Tone Detect HELP!
fire701
Grenada MS 38901
TDD- Mine is not e-mailing at all I checked to make sure e-mail was set up correct I can manually send a e mail but it will not do it automatically when it detects a tone.
Top 5 Things Answered problem with TTD
1. Operating System XP
2. Version of TTD V69
3. Has never worked on this computer
4. Log txt file- Successfully Received Local Tone info @ 13:39 on 6/26/2017
Tone 1
Tone 4
Then went to just 301.032766.9822488 continuously
Can you help?
DC31
Massachusetts
Tone 1
Tone 4
Can you help?
The 301 continuously means that you need to adjust your audio squelch level. It should say "no audio" when there is no radio transmission and show the freq during a transmission.
DC31
Massachusetts
I did this and it says no audio and when the page went out today it would not pick any radio traffic.
You are adjusting squelch in ttd and not on the scanner, correct? With it set properly on the scanner, then adjust it on ttd until you get no audio when there is no radio traffic. Then open squelch on the scanner and see that you show freq in ttd. Close scanner squelch and it should go back to no audio..
fire701
Grenada MS 38901
1. Adjusted audio squelch level on TDD only to No Audio
2. Open Squelch on scanner w/o speaker plugged in and it has sound
3. Plugged in speaker and still have it saying no audio with the audio squelch so high it has to be all the
way to keep it not sending numbers in debug TTD.
fire701
Grenada MS 38901
This is what I get on the screen now but it does not show where it is trying to e mail the MP3 file
Successfully retrieved Local tone info at 06:45:17 on 6/27/2017
Tone 1
Tone 4
Successfully retrieved Local tone info at 06:45:17 on 6/28/2017
Tone 1
Tone 4
putterizer
WI
Tone 1
Tone 4
Tone 1
Tone 4
The log file results you have posted above are letting you know that after you launched TTD the program retrieved the tone information from the tones.cfg file.
The log file you posted does not have the line in it that says it has detected your toneset, therefor no email would be sent. When it detects a toneset that you have it the tones.cfg file, it logs a line like this: {YourNameFireDept} page received at 05:53:44 on 06/28/17
To me, it looks like it is loading the tone info, but has not emailed because it hasn't sensed any tones yet. Have your tones been set off since you made the squelch settings change and launched TTD?
aaknitt
This is a screen shoot of the logfiles
This isn't showing any tone being detected. Confirm your audio connections and that the correct audio input is being used. On the main screen of the program it should say "No Audio" when there is no radio traffic, and changing frequencies when there is radio traffic or when you manually open squelch on the radio/scanner.
Andy
fire701
Grenada MS 38901
Andy
I got it to record and it shows movement on the graph when recording I have attached a screen shot on Tone Detector debug
mgl
aaknitt
Andy
mgl
It doesn't seem to be getting valid data from the sound card. Do you have a different sound card you can try?
Andy
fire701
Grenada MS 38901
Two Tone Detect
I tried it on another computer and recorded the weather channel so the sound cards works well, but it did not send a e mail with mp3 attached when the tone was sent by dispatch. I can send it manually as a test. This is a screen shot of Two Tone Detect D bug. Sorry for the sideways picture.
thanks
mgl
mattnelson26
Hopkins, Minnesota
issue getting audio from tone on my phone. i wanting to get edina chief and it just send a blank page no audio here is my logg of the page a few minutes ago
Waiting for Silence EDINA ALL CALL 19:01:45 on 07/10/17
Waiting for Silence EDINA CHIEF'S 19:01:45 on 07/10/17
Waiting for Silence EDINA CHIEF'S 19:01:46 on 07/10/17
Done recording EDINA ALL CALL 19:01:48 on 07/10/17
done writing WAV EDINA ALL CALL 19:01:48 on 07/10/17
Done recording EDINA CHIEF'S 19:01:48 on 07/10/17
done writing WAV EDINA CHIEF'S 19:01:48 on 07/10/17
done converting to MP3 EDINA CHIEF'S 19:01:49 on 07/10/17
Done recording EDINA CHIEF'S 19:01:49 on 07/10/17
done converting to MP3 EDINA ALL CALL 19:01:49 on 07/10/17
done writing WAV EDINA CHIEF'S 19:01:49 on 07/10/17
done converting to AMR EDINA CHIEF'S 19:01:52 on 07/10/17
done converting to AMR EDINA ALL CALL 19:01:52 on 07/10/17
MP3 Email sent! EDINA CHIEF'S page received at 19:01:00 on 07/10/17 19:01:54 on 07/10/17
MP3 Email sent! EDINA ALL CALL page received at 19:00:55 on 07/10/17 19:01:55 on 07/10/17
MP3 Email sent! EDINA CHIEF'S page received at 19:01:04 on 07/10/17 19:01:56 on 07/10/17
AMR Email sent! EDINA CHIEF'S Page Received at 19:01:00 on 07/10/17 19:01:56 on 07/10/17
AMR Email sent! EDINA CHIEF'S Page Received at 19:01:04 on 07/10/17 19:01:57 on 07/10/17
thanks
matt
