Two Tone Detect HELP!
DC31
Massachusetts
It is hard to tell what the issue might be from this limited info posted, but the first thing that i would try is to take the apostrophe out of Chief's. Special characters can do all sorts of strange things.
aaknitt
issue getting audio from tone on my phone. i wanting to get edina chief and it just send a blank page no audio here is my logg of the page a few minutes ago
Waiting for Silence EDINA ALL CALL 19:01:45 on 07/10/17
Waiting for Silence EDINA CHIEF'S 19:01:45 on 07/10/17
Waiting for Silence EDINA CHIEF'S 19:01:46 on 07/10/17
Done recording EDINA ALL CALL 19:01:48 on 07/10/17
done writing WAV EDINA ALL CALL 19:01:48 on 07/10/17
Done recording EDINA CHIEF'S 19:01:48 on 07/10/17
done writing WAV EDINA CHIEF'S 19:01:48 on 07/10/17
done converting to MP3 EDINA CHIEF'S 19:01:49 on 07/10/17
Done recording EDINA CHIEF'S 19:01:49 on 07/10/17
done converting to MP3 EDINA ALL CALL 19:01:49 on 07/10/17
done writing WAV EDINA CHIEF'S 19:01:49 on 07/10/17
done converting to AMR EDINA CHIEF'S 19:01:52 on 07/10/17
done converting to AMR EDINA ALL CALL 19:01:52 on 07/10/17
MP3 Email sent! EDINA CHIEF'S page received at 19:01:00 on 07/10/17 19:01:54 on 07/10/17
MP3 Email sent! EDINA ALL CALL page received at 19:00:55 on 07/10/17 19:01:55 on 07/10/17
MP3 Email sent! EDINA CHIEF'S page received at 19:01:04 on 07/10/17 19:01:56 on 07/10/17
AMR Email sent! EDINA CHIEF'S Page Received at 19:01:00 on 07/10/17 19:01:56 on 07/10/17
AMR Email sent! EDINA CHIEF'S Page Received at 19:01:04 on 07/10/17 19:01:57 on 07/10/17
thanks
matt
Are the other tone sets recording and sending properly and it's just this one tone set that's giving you issues?
Are you using a Raspberry Pi? You can get 0 byte "recordings" if the SD card is full.
Andy
mattnelson26
Hopkins, Minnesota
Andy
It is the only tone set that is giving me issue. no i am using two tone 68 on windows 10.
thanks,
matt
aaknitt
thanks,
matt
Did you try DC31's suggestion to remove the apostrophe from the tone description?
Also, it looks like it's detecting that tone set twice - is that what you expect to be happening? Is this a long tone or A-B tone? What are you using for settings in your tone configuration?
Andy
fire701
Grenada MS 38901
TTD not working correct
Andy I got a cheap usb sound card like you said and it is broadcasting my feed and I still cannot get the TTD to work.
I can listen to it and it is clear when they are talking.
do you have any other suggestions
fire701
fire701
Grenada MS 38901
This is what I get on the screen now but it does not show where it is trying to e mail the MP3 file
Successfully retrieved Local tone info at 06:45:17 on 6/27/2017
Tone 1
Tone 4
Successfully retrieved Local tone info at 06:45:17 on 6/28/2017
Tone 1
Tone 4
fire701
Grenada MS 38901
I attached a screenshot last time but I do not see how now so I had to cut and paste a old post everything the same now but the date.
DC31
Massachusetts
On your TTD debug screen, do you see numbers scrolling by when radio transmissions are occurring? Then do these numbers stop scrolling by when the transmission stops?
fire701
Grenada MS 38901
If I change the audio it starts scrolling but when I turn it back up it stops scrolling. But the transmissions does not make it scroll.
DC31
Massachusetts
If it is not scrolling when transmissions are taking place, then TTD is not hearing the audio. Check the settings for your audio device in the Windows control panel.
What are you "changing" with the audio that makes it scroll?
fire701
Grenada MS 38901
I had been e mailing andy and he said get a cheap USB sound card and try this so I did. It works well. You can hear the feed in MS , Grenada Co. Grenada County Volunteer Fire. It is clear except for a hum while their is no transmission going on.
fire701
Grenada MS 38901
I adjusted the squelch tone one notch and the screen started scrolling and when they paged out it wrote down in the white area Received the tone but it tried to e-mail it and failed. I can manually page out so I know they are getting out. Any suggestions.
DC31
Massachusetts
That sounds like progress. It looks like TTD heard the tone set. Open today's log (it is in the logfiles directory), find the tone detection and post the error messages
fire701
Grenada MS 38901
Somehow I can not get mine to attach a picture. So I guess I will type one part of the screen shot so you can see where the error is and it times out on sending the e-mail.
354.0 12694
Traceback (most recent call last) :
File "ttd.py" , line 51, in mail
IO Error: [Errno 2] No such file or directory: ' ./audio/Tie_Plant_Vol_Fire_2017
8_15_17_34_14.mp3'
Email not sent via smtp.gmail.com on port 587 using STATTLS on attempt 2 trying
again in five seconds for Tie Plant Vol Fire page received at 17:34:14 on 08/15
/17
345.0 12712.9623103
If you want to you can give me a e-amil address and I will attach my pictures of all screen shots for this page I received.
let me know
