Yaesu: tx problem ftm 350
dynamoaust
newcastle
What would this have to do with the frequency he asked about? 146.975 -.600 is 146.375 assuming he has the shift set correctly. If he has it wrong and at 6Meg, that still wouldn't land the radio on 144.005 or 143.975. I am just trying to for my own information figure out why you asked this question.
While I don't likely have the same version of the 350 he does, mine will transmit on 144.005 and the one not modded will transmit there. It will not transmit on 143.995. I have two, one was mars modded when I got it and the other one not so I checked the non modded one.
im thinking the radio has somehow reset itself to a 144 to 146 version now i need to know how to get it back to normal
dynamoaust
newcastle
From my experience, I doubt this is the problem. I once accidentally tried to update the firmware in one of my US market Yaesu radios with the European version firmware. It flat wouldn't let me. I kept getting errors until I realized my mistake and used the correct version.
It seems the OP is unwilling to respond to our requests for a picture of the radio's label, but keeps insisting this is a US market radio.
i never stated its a us model as it was purchased in australia
K9KLC
Southwest, IL
I have had two FTM 350s for years and done all kinds of programming on those and also same radio for others. I have never had one "reset itself". I'm not sure how that could even happen.
when purchased radio transmitted on repeaters normally
Ok so the radio was working and now suddenly it's not? You attempted no upgrades, no modifications whatsoever, or no other thing other than programming a new repeater and this has happened??
MTS2000des
5B2_BEE00 Czar
K9KLC
Southwest, IL
It is also possible the radio is suffering "EEPROM rot" like many old radios that rely on EEPROMS for memory storage and operation do.
Looks like Q1775 is where the magic happens. 512KB EEPROM.
If resetting the radio doesn't make it work, I'd be willing to bet this EEPROM is the culprit. Common part and it's about a buck.
While this is possible it would be odd that it suddenly went to the frequencies for a different region. I've seen this happen before on a bad attempt at a "mod", not saying that's what happened here but, still to exactly not get 145.995 and down, man that would be something. Good call however.
k6cpo
San Diego, CA
as stated prior radio is 350r
OK. I have the FTM-350AR, which is an updated version of your radio.
Do you have the original box? On the box there is a indication of the market the radio was intended for. Look under the model number for the word "Dest:" It should show you what market the radio was manufactured for. Normally, an "R" in the model number indicates a radio made for the US/Canada market, but I'm not sure that applies with this older radio. The only other thing I can think of is trying to reflash it with the original firmware available on the Yaesu.com website. There are three versions, USA, Europe, and Australia & New Zealand. You need to know which market the radio was originally intended for as you usually can't flash a radio with the firmware for a different market.
MTS2000des
5B2_BEE00 Czar
Possibly, but then a corrupted EEPROM can also result in errant and odd operation. The ROS on these devices isn't as sophisticated at what say runs on an OMAP radio like an XTS or L3H subscriber, so it could be interpreting stored data as garbage or out of band and blocking it. The key to this is the condition persists after a full reset
dynamoaust
newcastle
i am contemplating doing the mars mod in hope it will cure my problem of no transmit between 146 to 148 any thoughts
dynamoaust
newcastle
full reset changed nothing no trans 146 to 148
dynamoaust
newcastle
exactly
