N8IAA
you are right, but thats part of learning, and what might work for someone might not work for me... but you are right...
i wouldnt say i regret getting an HT first, but what ive spent in antennas and other stuff i could have bought a single bander and power supply. lol
that is one of the repeats i monitor, its almost intimidating to key up on some of them. there are sometime 4-5 people rag chewing and they all know their stuff very well... once i get my signal cleaned up a little id like to take part in a traffic net...
i think my problem is my expectations for a HT were to high. i was thinking i would be able to lay on my couch and chat away with the rubber duckie... WRONG lol plus my aluminum sided house is a big hurdle to get over... but i am learning and will get their eventually...
Since you have access to your attic, get an antenna that is made for 6m, 2m, and 73cm. A decent mobile antenna will work. Larsen used to make a base mount that used a SO239 connector. It included ground plane whips to improve the angle of radiation. Feed it with quality Mini8 coax terminated in a PL259 connector that can accept a SO239 to SMA cable for connection to the ht. I use a magmount dualband antenna mounted on a 4 drawer metal cabinet in my shack. Using just an ht at medium power, I can be full quieting on 3 out of 4 of my metro repeaters. Some of which are 20+ miles away. Am without a mobile rig right now, but, it was the better choice of rag chewing on 2m and 73cm. It will save the transmit finals in the ht. I originally lived on the westside of Cleveland. I truly was blessed that most of the repeaters were located at an elevation and sites close to me. I used to use the duck that came with my ht's on low power for my contacts. My first radio was a 2m ht, with an amp. Used it until it until a 2m mobile was purchased. Only regreted the ht when trying to get into simplex nets and others where using a whopping 25 watts
Just a short ramble on my part,
Larry
