BCD436HP/BCD536HP: UBCD3600 - RECORDING DMR SLOTS
Hivizdan
United Kingdom
Hi All,
I was wondering if anyone could shed some light on listening and recording DMR Transmissions.
I'm in need of recording some DMR Traffic on a repeater I will be using, however it will record both Slot 1 and Slot 2, is there a way to preference which slot is being listened to?
I have programmed the frequencies in the scanner via Sentinel, but the only option I have is Color Code, there doesn't appear to be an option to favour S1/S2?
Could anyone shed some light on this?
Dan
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Be sure to turn on ID Search after programming as OFT assuming said repeater & TGIDs aren't documented in the RRDB
JoeBearcat
Uniden Representative
Hi All,
Dan
There is no slot priority.
u2brent
OAMPT
KRWDPAXKRS1
If you program as oft, you can program both slots and avoid the one, either temp or permanent. Adjusting delay may help as well.
u2brent
OAMPT
KRWDPAXKRS1
You would select,
DMR One Frequency
Create a Site
Create a Department
add frequency and TGID's
