The only way to truly know if you have the issue is to measure the noise at the negative side of the middle battery. The noise may be there and my guess it is. You may have no trouble hearing what you want to hear. Just today I found a DMR repeater that is probably about 60 - 70 miles away. That comes in perfect with the shielded battery door. Once I remove the door. Zero. Not even a hint of a signal. That is with the stock antenna, not an external antenna. Since you are new to the thread this noise does not cause any problem if you are using an external antenna. Once the antenna is moved away from the noise source the issue goes away. If I am wrong I am glad you got a good one.
One would tend to think it still would have an affect with an ext antenna. Cant a signal even further away fall prey to the noise?
