jeffm77
I intended that message for Mule1075, as he stated he doesn't have the problem or even heard of the problem.
You are seeing exactly what I found. However in my case aluminum foil did not work. Keep us posted.Kevin,
Can you post some pictures of your quick tape job, for curiosity sake?
Greg
My stock batteries are end of life. I have Nuons in mine. I tried Duracell Alkalines no change.Has any of the testing been done with aftermarket batteries compared to stock batteries?
Now to decide on whether copper tape or conductive coating is the better choice.
I do not have an SA but thought I would give the Airspy a try. I probed the rear case with a rubber duck attached to the Airspy. I also see 20db increase in the noise floor with the cover off. When I put the shielded cover back on. I still see about 5 - 8 db of noise. So a better tape like copper EMI/RFI may yield even better results. I realized that my method is not very scientific but it does show the changeI did a quick measurement with my spectrum analyzer. Around the middle battery the noise floor will rise about 20 dB in the UHF range (it might in other areas also, but I didn't test elsewhere).
You can actually watch the radio power up/down as the noise floor will rise before the "on" beep and stay elevated after the "off" beep.
I didn't test any shielding, so I can't comment on that.
I wonder how many people who don't suffer this issue have swapped the stock SD card (for one with better shielding?), stock batteries (for ones that accidentally provide better shielding?), or have turned off the "always on" recording feature.
If I had that spray stuff (and this problem) I'd be tempted to mask off the SD card contacts and give it a good dosing. My guess is the interference is from a harmonic of those cells constantly being written during recording.
Sent from my SM-G935W8 using Tapatalk
Some people have posted they do not have the issue, but then I come to find they use external antennas. That will solve the problem also. Moving the antenna away from the radio. I turned off the recording and the noise floor still goes up 20db at the center battery when probed. I shielded the center battery and with no joy. Your points regarding SD cards with better shielding is not something I could comment on. I do have two different brands and they both do it. Shielding the opening for the SD card did not help.I wonder how many people who don't suffer this issue have swapped the stock SD card (for one with better shielding?), stock batteries (for ones that accidentally provide better shielding?), or have turned off the "always on" recording feature.
Exactly what I have found. I am hearing tons of things that I never could hear on 436 before this. My comparison was always the 396 or 330 which heard them fine. Looking forward to getting some tape designed for this purpose.I really feel as though I'm missing something and this "fix" is actually a placebo, but I just tried another frequency (analog).
Without the cover lots of noise and barely able to understand, with the cover almost full quieting.
I'll see if I can do that tomorrow.Jay since you do not have the problem. Do you have and RTL or Airspy or something to see if your noise floor goes up near the center battery? I put SDR sharp on 460.000 and turned up the gain to where I see signals. Then probe the center battery with a metal antenna on the end of the SDR. Might be interesting since you do not see what some of us see.
I wouldn't write it off that quickly. See section 4.4 of http://www.ti.com/litv/pdf/snoa382 and consider the harmonics those step functions produce. Ugly.The source of noise would not come from the low level digital 1's and 0's being written to the SD card.
Exactly what we need. He seems to have a vast knowledge of the components. He may be able to identify the issue. I really think we are on to something here.darunamil was kind enough to field strip his radio so we can all view the PCB. It seems the main radio guts are very well shielded. So for the average user, shielding the battery compartment from EMI/RFI leakage is probably the best we can do to prevent the noise from hitting the antenna, which is the end result everyone is looking for.
