Yes, to reduce the possibility of accidentally turning the unit on or off.
Back on topic:
This whole noise issue is WAY overblown.
If you use any external antenna--i.e. any antenna not directly attached to the scanner, such as an outdoor base antenna, or a mobile antenna mounted outside the vehicle, the battery compartment noise has ZERO effect on reception. Zip. Zilch. Nada.
If you use a BNC duck/whip antenna like the Diamond RH77CA and the SMA-BNC adapter included with the scanner, the antenna is moved far enough away from the body of the scanner that the battery compartment noise has very little impact on the received signal. This has about triple the noise reduction effect gained by shielding the battery door, and has the added benefit of making it easy to switch between handheld, mobile, and base use, and all of the contact wear associated with switching antennas happens to the SMA-BNC adapter, rather than to the SMA connector on the radio. So it's not a "kludge" to avoid a noise problem, it's a good practice with several tangible benefits.
The ONLY circumstance where the noise is a significant issue is when using a relatively short SMA antenna such as the stock duck (longer antennas pick up less of the noise because more of the active element is farther from the scanner body) connected directly to the scanner. And that is easily avoided by using the included BNC adapter on the radio and then putting a BNC adapter on the duck, to move it away from the radio a little. Which has a greater effect on reducing the noise than shielding the battery door.
https://www.amazon.com/Maxmoral-Female-Coaxial-Adapter-Connector/dp/B0114MWLX6/
