BCD436HP/BCD536HP: Unable to receive Hytera DMR Tier III Trunked System
PurityControl2
Hey everyone, I'm aware there is or was a software bug for the 536HP regarding the scanning of Hytera DMR Tier III Trunked systems. I have the DMR upgrade, my scanner is the latest version (1.28.17, 6/12/2024) and I simply am unable to receive Trinity EMS in Torrington on the Homeland Defense Network system in CT. I am within range with full signal. When I append it to my favorites list with Sentinel (Master DB is up to date) as a MotoTRBO system, I receive absolutely nothing. I can hold on the system and observe full signal but get no audio. I tried programming the talkgroups as DMR OFT's, and I get some voice, but it's very spotty and most of the time captured as just silence on ProScan. It has also captured UID's when programmed as OFT. I have an open support ticket with Uniden for just about a week now, they have not responded to me yet which is fine, it's just a few days after the holiday. I'm wondering if anyone else has been able to fix this issue, because I bought the DMR key specifically to monitor this system and at this point, half a year later, it's gotten quite frustrating. I have read that the 996 and 325? both have received updates that have fixed the issue. My favorites list is attached.
  • Litchfield County.zip
BC_Scan
Vancouver BC
I have one 800 mhz Hytera T3 system with LCN discovered ( i can track all the tg's), just a quick look depending on which tower you are listening to I dont see LCN order , is that an issue that those have not been discovered ?, you have not mentioned that you have those in order , maybe they are not discovered as of yet , have you tried ANALYZE- LCN Finder ?
I see that they are there those if correct are required the other thing is they may have changed
PurityControl2
The LCN's are listed in the RRDB and are programmed/imported in
BC_Scan
Vancouver BC
i would try re-analyzing the site to see if the order is still valid
how many rx sites are you trying to listen to ?
Hit_Factor
Saint Joseph, MI
Might not be correct. Run the LCN finder, read the scanner into Sentinel to see/compare results with the RRDB.
It's OK to guess on missing LCNs or if a pattern seems to be emerging. You won't break anything, it (still) won't work if wrong.
PurityControl2
@BC_Scan , @Hit_Factor thank you both, I'll run the LCN finder and if the results are different from RRDB I'll submit it to the DB, I'm also only attempting to listen to the Torrington site. Thank you both and I'll report back as soon as I can!
BC_Scan
Vancouver BC
if it were me and there is a 2nd site withing scanner earshot I would be listening for that as well
3 fx only on your site not much , system owner may stack that tg you want onto another tower and your out of ear shot only listening to one site if possible look for other control channel your scanner will hear, might have to push the antenna up !
PurityControl2
@BC_Scan @Hit_Factor even after running the LCN finder, (it found 1/3, and the LCN was different from the RRDB) and inputting the correct LCN for the correct frequency, it did not make a difference. I'm only in range of one site/tower unfortunately. I only ever seem to get captures on the 461.8125 control channel frequency
cg
Connecticut
The Hytera DMR fix in the Uniden 325P2 & the 996P2 have not yet been pushed to any of the remaining Uniden DMR capable scanners. That would be the 436/536 and the SDS100/200.
The 325/996P2 firmware was completed the last week of October 2024 and none of the others has seen updates since late spring of 24'.
BC_Scan
Vancouver BC
now you are onto something , if all three are entered correctly it can take + -24 hrs more dependant on traffic on the other two channels , i suspect you are in fringe if you can only get one tower. I would keep at it as it is the key to your success regardless of any updates (also weak signal doesnt help) thats why I suggested /asked about antenna , what is it and how high is it (please dont say its supplied whip :rolleyes:) you might as well be using nothing then
PurityControl2
@cg Ahhhh okay, I figured the others also received the update too. Well, hopefully the fix will be out soon! Definitely looking forward to it!!!
@BC_Scan I'm only a couple miles away from the tower so range isn't an issue, I have the Diamond RH789, and it's sitting next to me here on my desk, but yeah the issue is unfortunately a software bug and hopefully the fix will be out soon :) Thank you guys!!!
dmfalk
Eureka
And those of us with these scanners are still waiting.....
hiegtx
Mentor
Dallas, TX
So this means If you have a BCD996P2 scanner you have to wait til they push it out to update
Go back & read that again. I think you misunderstood.
As cg's post noted, the update was issued for the 996P2 and 325P2. See this. What cg was saying is that while that specific update was released for the P2 scanners, an update for the x36HP & SDS series scanners, for the DMR Tier III issues, has not yet been released.
So you can update the 996P2 (or 325P2), but so far, a similar update, specifically for the x36HP & SDS series scanners , has not been posted/
JASII
Memory Capacity
Are we still waiting on this for the x36HP & SDS series scanners?
PurityControl2
According to post #14 we are still waiting for the fix on those 2 scanners. I don't think I have any DMR Tier III in my location anyway.
The update is out, it's been out. https://info.uniden.com/twiki/bin/view/UnidenMan4/BCD536HPFirmwareUpdate
1.28.24 Release Notes (03/24/2025)​
Release Notes
The following improvements have been implemented.
  1. Supports DMR Tier 3 Multi-Block VCH Grant.
  2. Improved to detect DMR Tier 3 Capacity Max late entry messages.
  3. Added Weather EAS event codes: SQW, BLU, EWW, SSW, SSA
