Unication for railroad?
INDY72
Indianapolis, IN
Has anyone ever tried to use an Unication G series for rail yet? If so how does it fare?
INDY72
Indianapolis, IN
You mean as a scanner? Works just fine.
Limitation is the internal VHF antenna means you won't get stellar range.
Thats exactly what I was wanting to know. I had never heard anyone using one. I figured that since I am planning on getting one, I can get multiple usage out of it, and they are awesome on VHF as much as on 7/800. Just won't be as useful for rail once the NXDN roll out finally really starts.
OpSec
All your WACN are belong to us
Monitoring the database
I've been using G5's for years. I have several zones setup with knob 1-7 set up as individual channels for a certain area and knob 8 is scan for that zone. Smokes most scanners for sensitivity.
Once you are used to the clunky interface, I prefer it to trying to make favorites lists in my Unidens.
INDY72
Indianapolis, IN
I am even more interested in one now that the C version is around. USB-C interface for charging and programming. Other features on the new ones too from what I am seeing. :)
willdanl
Dripping Springs, TX
My G5 picks up a VHF P25 system in the next county better than my SDS100, BCD436HP and PSR800. So that internal VHF antenna isn't too shabby.
wa8pyr
Staff member
Lead Database Admin
Ohio
Yeah, have to concur. I've tried my G5 for rail monitoring, and while it worked, reception is not too great. It only worked well (sort of) when I was close to the tracks; that internal antenna is a definite limiting factor.
INDY72
Indianapolis, IN
Too bad they don't have a set up so the attached antenna can be used.
burner50
The Third Variable
NC Iowa
I recently bought one... The G5+
wa8pyr
Staff member
Lead Database Admin
Ohio
Yep for what I got mine to monitor I've seen no scanner better (haven't had hands on a 150 yet) and it honestly kept up with a subscriber radio side by side for the hour we got to test it. (Simulcast system).
Yes, but the topic here is using one for monitoring VHF railroad transmissions. Let's keep it on topic.
