Unication G-Series Voice Pager with Digital Trunked Scanner Feature
signguy10
Saint Paul
Thank you for the feedback on #1, I will have to play around and see if holding and unholding is easier or breaking down my programming, even more, to have them all non-priority with fewer talkgroups in each area.
I found #2 out with the help of another G5 owner, I didn't see the volume level for the notification tone. I turned the volume down and it is much more tolerable!
trido
Retired 32 years scanner sales
Southern In
I am told this RR TG import tone alert defaults to NONE is the only change.
New PPS for scanner beta users of v 1.40beta, changes RR TG import tone alert to NONE.If I see any other changes I will post.
Please use below link to download the newest PPS software, thanks.
G5 PPS Software Download Link (version : V00.03.17_beta12)
G Series PPS V0.3.17 Beta12
rimedic
Is this locked by serial number still
Or can anyone load it?
bob550
Albany County, NY
I'm still at 1.2. Could I or should I upgrade to 1.4 beta?
You can upgrade to firmware V1.31 and the accompanying PPS 3.16.24. If you already haven't done so, you should read the comments on the 1.4 beta. While Unication advises against downgrading from 1.4 to 1.31 or earlier, many have done this due to problems with the beta. Additionally, Unication's announcement of a pending scanner product pretty much says that the 1.4 beta will be orphaned at some point.
markjrenna
NJ
Thank you!!!
Oh pending scanner? Any info or links? I could not find anything official on that?
Anderegg
Enter text in this field
San Diego
I like how there website is configured as PPS 🙃
Paul
trido
Southern In
As far as I know it is still locked by sn.
QUOTE="rimedic, post: 3523592, member: 204255"]
[/QUOTE]
jabbeaux
Germany
Still locked to serial number by the firmware updater software.
But there is a version of the updater software that will install v1.4 on any pager. It’s floating around the web.
jabbeaux
Germany
Any idea where? I've been looking with no luck.
Bob
Sorry I don't know how to answer this without breaking a forum rule. I think we can talk about software and say we have it, just can't give out links. In posts or PMs. I guess best I can say is there's some radio chats in Discord and members there have it.
WeldGuy
Canal Winchester, Ohio
I just purchased a new Windows 11 desktop. I was hoping I could download the PPS program and plug in my G4, transferring the programming to the new computer. However, I don't see a way to do that.
If that isn't possible, what folders do I need to copy from the old computer to the new one so I don't have to re-enter all my Profile information?
wx9kvh
Radio Nerd!
Outagamie County, Wisconsin
Just read the pager with the software on the new PC.
Anderegg
San Diego
What he said, or I think you can EXPORT an XML or something from the old computer...that method is also used for CLONING G's, even ones with non matching model or bandsplits (G5)
Paul
AGRadioNut47
Montco PA
I have question about the g5 pager. I am using the slience scan mode on the pager for two tones. Can you alert all three channels for the two tone or just the first channel that you select to go off. I know on the mintor 6 you can scan the two channel and it will go off. Can anyone help me out with this.
Thanks Andrew
WeldGuy
Paul
OK... figured out what I needed to do to copy the data from the G4 to PPS.
NOW.... facing another problem. I want to add another Knob Position - Highway Patrol (local post).
I previously added a local PD, so I followed the same steps when adding the OSP info.
Under the GROUP ID SETTINGS tab, I clicked on the [NEW] tab and added the new Alias Name. When I click on the [SAVE] tab on the bottom I get the following error.
All protocol is \"No Setting\"
Please check again
I did not get that error when I added the Local PD recently.
What does that error mean?????????
