Unication G3 / G5 won't connect to Windows 11?
sefrischling
Public Information Officer
New London, CT
I have been using a Windows 7 laptop to program my G3 and G5 without any issues for 4+ years, now that I switched to a Windows 11 laptop, since my trusty ole' ToughBook has moved on to a better place, I cannot get either the G3 or G5 to connect when I launch the PPS to and connect the USB cable.
I have tried both USB ports, I have tried multiple cables.
Any suggestions?
Any suggestions?
Have you tried to download and installing the Unication driver again?
sefrischling
New London, CT
In Device Manager under ports what port does it say when pager is connected?
Do you have a Yellow Exclamation Point on the Driver under Ports.
No, it shows as it is working. The computer sees it, but the PPS doesn't show anything connected.
N6ML
When you connect the USB cable (and the pager is on), in Windows Device Manager, you should see a device identified like "Unication USB Ethernet/RNDIS #x". If you don't see that, the driver is not installed correctly. I know you said you reinstalled it, but just to be clear - there is a separate driver package (separate from PPS) available for download, and that can sometimes help in these situations.
If you do see the correct device, it may be that some malware protection software is preventing communication with the pager. Search this forum for "Norton" and you'll find several reports of it needing to be told to allow PPS to communicate.
maus92
The OP
I have noticed that the latest V4.x version of the PPS connects almost instantly with my 5+ year old G5, unlike the V3.x variants. V2.02 firmware. My programming PC uses Windows 11 Pro, fully updated and is of fairly recent vintage - 8th gen Intel.
