Unication G4/5 Bluetooth Speaker Choices
krokus
Southeastern Michigan
Inside the hotel in Romulus, about 15 miles west and the last signal I heard was on the road about 25 miles east in Ontario on Route 401. I came in through Toledo and had signal well before I got on 275.
I have not driven on 401, but that looks like a clear shot, and I know the approach from Toledo is. The signals do not carry quite as well to the north, the last time I tried.
Citywide173
Attleboro, MA
I could never get a signal at the hotel, even on my mobile mounted 996XT connected to an Austin Spectra which does gangbusters within 5 miles of the city limits. The video was taken (obviously inside) on the first floor at the western end of the motel. I have tried multiple portable scanners with stock, 800, suction cup dipole and homebrew (BNC to screw post with correct length wire for frequency) antennas with no luck whatsoever in the past. Couldn't even hear the data on the control channel.
KI5IRE
Oklahoma City
I know this has been asked somewhere on the forum before, but has anyone had any luck pairing a G4/G5 to something like a Motorola Bluetooth RSM or PTT pod? I am looking for something I can clip on my shirt or backpack with a pretty loud speaker (I know the Motorola stuff is loud) for when I am on fire scenes. Also was looking at the PTT pod for scenes I am at where I need to be able to listen with an earpiece only. I am a news photographer so I am frequently on scenes where it’s nice to be able to blast my radio without an earpiece like a fire and 10 minutes later I might be standing in front of a SWAT scene where it’s best to listen over an earpiece.
IAmSixNine
Dallas, TX
I have one of these from Klein and it does not work with the G4. Blu-RSM® Bluetooth Speaker Microphone
It does work with my BK KNG2. Motorola has some proprietary stuff with their radios. So have not tried it with my XPR7550 yet. I was told it would not work. Or maybe it was the PTT that would not work but the SPK would. Either way the XPR has not been tested.
fmulder13
Minneapolis, MN
I was in Detroit for a few days this week. First, the G5 did better at reception than any radio I've ever owned. I was receiving Detroit 20+ miles outside the city limits, which I've never been able to do in the 12 years I've been going out there. I recently picked up a Galaxy Note 10+, which does not have an earphone jack and I really didn't want to wear two bluetooth headsets (Unication and my Plantronics) so I picked up a pair of Samsung Galaxy Buds. Good and bad news. The earbuds would not connect to two devices simultaneously to allow both my phone and the G5 to be in my ear (I didn't put a lot of effort into troubleshooting this), but they could be used with just one earbud in at a time. They paired without problem to the G5 and the best part of all was that there was no connection tone (ringing) before each transmission. It worked great for my needs.
Thanks very much for the tip on this! My Motorola Sliver II (works great with my G5-no beeps, good, loud audio, in case anyone has one lying around) bit the dust, and I replaced it with a pair of Galaxy Buds upon your recommendation. So far I'm really happy. The small form factor of the Galaxy Buds is awesome, as is the ability to use 1 or 2 at a time and charge them in the case. Audio is a little low, but I think it will be livable.
fmulder13
Minneapolis, MN
I’m noticing a delay in passing audio with the galaxy buds connected. Has anyone else experienced this? The first part of transmissions is sometimes cut off, especially when scanning a zone with a lot of talkgroups. This only happens on Bluetooth. Perhaps it’s a processor speed issue.
JD21960
ILL-annoyed
Did you turn voice buffering ON or off in tab 5 of the PPS for your Zone box? it tells you before you save it "the front parts of transmissions could be cut off unless you use voice-buffering on"
IAmSixNine
Dallas, TX
If @Johnnydollar2 suggestion doesnt work it may be a limitation of the V2 BT that unication uses. With that protocol it has to establish an audio connection each time a call comes in. Then when the call is done, the connection drops.
fmulder13
Minneapolis, MN
I think that might ultimately be the case. I've been playing with turning voice buffering off and on, and the same results happen. Furthermore, there's no delay/cutoff without bluetooth. Maybe firmware updates can address this, or maybe it just is what it is.
blackbelter
So your Motorola silver 2 head set paired with G5 and loud audio?
N2YQT
Ambulance Driver
South Glens Falls, NY
Has anyone tried taking a Bluetooth receiver paired with the pager and feeding the audio into a Bluetooth transmitter that uses a newer standard?
krokus
That is for paging, and buffering the radio traffic audio while the pager is alerting.
krokus
Unication has stated that the audio is processed via the BT phone connection protocol, and a "new call" is generated for each radio transmission.
fmulder13
Minneapolis, MN
Like a charm, more or less. Before firmware 1.2 it had a short beep at the END of the transmission, and post firmware 1.2 it was beep-less. It still cut off the very front of transmissions however. I'd miss unit numbers, sometimes entire transmissions, just like I'm experiencing with the Galaxy buds.
JD21960
ILL-annoyed
[/QUOTE] -
Yes, that was posted before 1.2 firmware fixed* it if I remember.
I'm glad my Jabra BT ear-pieces aren't doing that. They're perfect just as all my BT things are. I'm guessing it's a problem with his device of choice.
fmulder13
Minneapolis, MN
[/QUOTE]
Your Jabra earpieces have no delay in passing audio?
DewAddict
SE, Michigan
This is what I'm curious about as well. I don't want to spend $700 just to try it out. I had a G4 two years ago and it just didn't get loud enough in the vehicle for me along with a few other issues.
On a side note, are the new G4/G5 units shipping with a newer Bluetooth standard like 4 or 5, or still v2.1? I see the new G2/G3 have Bluetooth v4.2.
winstonsf
Does not seem like it. I received a new G4 replacement unit from Unication USA A couple weeks ago and it shows Bluetooth 2.1.
IAmSixNine
Dallas, TX
I know this is an older thread but I wanted to do a follow up.
My Blu RSM will pair with the G4 now. So nice to see Unication tweaking bluetooth settings.
