Unication G5 Oddities?
hill
Middle River, MD
Yeah the 64 Talkgroup monitoring seems kinda crappy considering you can define 1024 TGIDs
64 talkgroups total sounds about right to me and maybe too many with many Profesional users using a limited amount of scanning. If something big breaks I can change to different zone/knob position to hear the incident.
Going forward too many talkgroups scanned at once will most likely cause you to miss a lot of radio traffic. This is why I use multiple radios to monitor with only scanning a limited amount of stuff.
K9KLC
Southwest, IL
So I dunno if I got a firmware bug or something, cause the firmware version on my G5's appears to be one version ahead of what is publicly available. Unication website says v2.02 and v2.03 are latest available, but autoup shows v2.02 as latest, but our pagers have v2.03.
Because your pagers are "new"....2.03 is only available for the new(er) pagers. 2.03 has never been made available for download the newest we can get for "older" pagers is 2.02. If the pager is "new", 2.03 is what came on it.
K9KLC
Southwest, IL
This is 100% the situation. It took me programming my Unications to finally figure out why some of the other stuff I used to monitor with wasn't working the way I thought it should. I scan only about 48 TGs in my area on the system I monitor and still end up missing "agency a" while "agency b" is talking. Multiple monitors is the key. (at least for me YMMV)
Synapt
Johnstown, PA
So then the 2.02 works the same way? Unication just has a different concept of Scan vs Monitor than the Minitors do? No real silent mode other than being off-duty?
I never thought to really check this with unication before ordering them, I did a good thorough check of the documentations before we did (since I knew I would be the one programming them), but the documentation definitely didn't quite detail it would be like this lol.
I just saw the same labeling that Minitors used and assumed they would be the same way. Definitely at least never thought a "Scan" option would also audibly monitor since there was an explicit monitor one.
K9KLC
Southwest, IL
The firmware's as far as I know work the same. I don't have anything with 2.03 but I can't imagine any functional differences.
Unfortunately I can't comment to the "off duty " stuff. Maybe I'll have to mess with that some when I get another pager and see what all it does or changes. Right now I'm not gonna mess with the one the wife uses and mine has taken too long to get set up (for the most part) the way I want it. I'm waiting on one to come back from Unication under warranty.
Synapt
Johnstown, PA
Well basically let me put it like this. Assuming your unication is public safety use (ie; it's tied to a main dispatch/command talk group), can you always hear what's going on over that even without your tones going off first? Or do you only hear dispatch chatter after your tones go off until you reset it, similar to how Minitors work?
