There's a speaker / earphone jack... But all the jacks on the back should be labeled.
Yes, you are correct. I wasn't looking at it when I wrote that post.
The manual just posted has the pinouts for the other jacks.
Maybe we could convince Unication to include an earphone jack in the next model.-Does anybody happen to know of a suitable mobile speaker that would work well with the Unication G5? I am thinking that one that connects to a micro USB cord for power would be nice.
-What are people here doing for mobile mounting? I tried my PanaVise 777 ClipCaddy Holder, but the belt clip is just a bit too wide to work with it. Does anybody know of any other competitors for devices similar to the PanaVise ClipCaddy that would accommodate a wide belt clip? PanaVise Products, Inc.
-Has anybody here bought the drop in amplified charger? I would think that having that connected to a higher gain antenna would be quite handy.
-What other antennas have people tried with this so far? I am still using the Motorola DTR550 on mine and it is working quite well.
-I haven't done much with conventional channel monitoring yet. Is that also limited to 64 conventional channels?
Does anybody happen to know if other belt clips can be attached to the G5?
The belt clip appears removable. Is there another one that will work? Not sure. Maybe a 3rd party might make one. Is there something you don't like about the belt clip?
Anyone with a G4 or G5, are you able to go into the menu and select some type of 'monitor mode' for a trunking system? I can't seem to find a way to do it in the software but I've read it can be done in order to pickup all talkgroups on the system even the ones you don't have programed in. When I select monitor mode for a knob position instead of TG scan it just gives me the option for conventional freq range.
Also, has anyone tried putting in FFF wildcard for all system settings and turning full spectrum scan on to see if it would scan and 'discover' a system without anymore information programmed?
Anyone with a G4 or G5, are you able to go into the menu and select some type of 'monitor mode' for a trunking system? I can't seem to find a way to do it in the software but I've read it can be done in order to pickup all talkgroups on the system even the ones you don't have programed in?.....
That not so good when there are 325 TGs and many are encrypted.Yes, on the device, select Menu, then Function Status, then 3. Monitor Mode, then On, then select Set. It will monitor everything.
Hello my name is David and I'm product support for the G4 and G5. If you have any questions that you would like to ask me please feel free to do so and I will answer them as quickly as possible. You can also email your questions to me at David@unication.com
-Does anybody happen to know of a suitable mobile speaker that would work well with the Unication G5? I am thinking that one that connects to a micro USB cord for power would be nice.....
.....just out of curiosity are you having trouble hearing it while in the car or would just like more options?.....
Hi David
Thank you for coming here to Radio Reference and being willing to answer questions for us.
Any update on when phase II capabilities will be available? I'm ready to purchase but need phase II.
