Unication *New* G4 and G5 pagers/ somewhat limited scanner
cpetraglia
Fairfax, VA
I hate to say I have not had the muffled audio problem, because I don't want to jinx mine. :)
However, I also haven't "pulled the battery", and my battery was already installed when I received mine. Is there by chance any correlation between removing the battery and the audio problem? Just wondering if it's a physical problem due to something being pushed up close to the speaker, or pressing on the speaker, that's worse due to heating or battery placement.
Back to lurking.
I too have been using my G4 for about 4 months now and not had the audio problem. I use it 24 hrs a day most of the time. Just lucky I guess.
Thunderknight
Bletchley Park
It really seems to vary by unit. My first G5 did it. My replacement G5 has not done it at all (fingers crossed).
APX8000
Sarcastic Member
AES-256 secured
Dave I got in my car and turned on the G5 just now. Muffled low audio from the start. Went to do a battery pull and still had the unit on. As I started loosening the two screws in the back the audio corrected and the muffling went away. Don't know if this helps or not.
Ever since I backed off the screws a little bit I have NOT had the audio problem. Been listening non stop since, unit off, unit on, changing systems, different volume levels...again, don't know if this is coincedential.
hiddenrun
Commonwealth of Pa
Signal-Zero, I had this very same issue this week and also shared this with Dave right away.
My Audio went low, I loosened the screws and the audio came right back. I also then removed the cover and made sure it was seated right, then installed it again. I did not experience the issue since then, although I do not monitor all the time.
EMTBob
Mount Pleasant, Pennsylvania
I have had My Unication G-5 For 2 Months and yes it smokes the P-25 Scanners and works very well with a Simulcast system I use mine with my counties Simulcast system and it hears things my P-25 Scanner does not. Just My .02 Cents well worth the price but I Traded in some G-1's and a Minitor v and got a great Deal that I could not Pass up. Remember it's a Professional Pager.
APX8000
Sarcastic Member
AES-256 secured
Well I jinxed myself...turned it on today and low muffled audio. Powering the unit on and off and the three button reset did not work. Again pulled the battery and audio is fixed.
forums manager
Super Moderator
Staff member
Super Moderator
Thread closed.
With a new forum available, individual threads should be created instead of one large, unwieldy thread.
