Unication *New* G4 and G5 pagers/ somewhat limited scanner
David_Oney
Former Unication Tech Support
Raceland, KY
R11J is the current release firmware for everywhere but Michigan and select areas so if you have anything earlier then get with me
David_Oney
Raceland, KY
Being in Michigan, that got my attention. Are the differences able to be disclosed?
Sent via Tapatalk
Michigan has only approved firmware 1.01 currently they work very closely with us and like to thoroughly test each firmware before approving it.
Thunderknight
Bletchley Park
Is J newer than K? A poster above yours has K, but you said that J is the latest.
J comes before K in the alphabet, so it seems counterintuitive.
David_Oney
Raceland, KY
K is newer than J, Sometimes i release a newer firmware to a limited few just for testing purposes.
BenScan
D/FW
Is there a way to copy the Unication G5 or G4's recorded audio to a computer? I don't see any obvious way to do that.
phirephoto
Fremont, CA
Currently, no. But I did suggest that to Unication a few months ago. Would be a valuable feature!
David_Oney
Raceland, KY
We have been working on this feature. I have just been authorized to allow the members of this forum to test this utility. Remember this is a very early version of the utility and may be different from the final version. It may also contain bugs that have not been discovered. All I ask in return is that you give me your feedback so that we can make improvements on its final design. To receive this Utility please send an e-mail to david@unication.com to receive a download link.
BenScan
D/FW
Thanks. That'll work! It's take a long time to download 1000 messages, and I didn't see a way to cancel it, so I just let it run. If possible, adding a Cancel button to the downloading message box, would be nice.
I'm not sure how much I'll actually need to use it, I think if the text files included the actual talkgroup ID on trunked systems, instead of what appears to be an index number in the pager's database, it would be more useful.
voice File Name: AG5V660088_20160729_130912.wav
Received time: 2016-07-29 13:09:12
From ID: 0
From Name: [7211820]
To ID: 19 <----- make this the actual talkgroup on the trunked radio system, not the memory index in the pager.
To Name: FW Fire 4
Protocol: P25 Trunking
  • TestG5MessageBackupAudioFiles.zip
D
darunimal
Guest
if you just used a scanner you would have the record capabilities there or buy a Moto and hook it up to a PC full time and record on your windows machine, or maybe some SDR dongels see it would be so easy.
