I have a remote Uniden BCD996T (no X) that was receiving the NAS Key West trunked radio system just fine for a couple years.
This morning they are conducting an exercise making extensive use of the trunked system and I found a bunch of new talkgroups. I added them to FreeScan the same way I always have, programmed them into the 996T, after that nothing.
I can hold the scanner on the control channel and see the system ID 14C-205 as well as the talkgroup activity flash across the display, so it's finding the talkgroup names that I've programmed into the various groups.
So what are the magic settings for this DoD P25 system? It worked fine, then 2 minutes later after I reprogrammed it the thing won't receive any more. It had to be something I changed inadvertently, but what?
FreeScan
Trunked System Setup
Type = Mot Type II / P25
Use Motorola end code
Use digital Motorola end code
ID format = decimal
ID mode = ID search
Site Setup
Site type = Mot P25 / P25 Standard
Modulation = Auto
The 4 frequencies are entered, not locked out, all have LCN = 0 since that doesn't matter.
What else?
Thanks.
FreeScan
ID format = decimal
ID mode = ID search
Site Setup
Modulation = Auto
What else?
Thanks.
