Please provide a link to the cable you have.
That’s the other one I ordered . Thank you for welcoming me to the club.Prob need one of these. Or return the cable you got and get native USB Welcome to the forums
I use the original serial cable that came with all of my older scanners, including my BCD996XT's. The USB to serial adapter I suggested is the one I use. I have never had a problem using that adapter with any software or scanner. I am currently using it with a Windows 11 computer.That's a "serial" based cable not used as much these days. There is no guarantee that a "usb-serial" adaptor would work in this situation.
I have the exact scanner, including a large number of others all using the mentioned cable.I use the original serial cable that came with all of my older scanners, including my BCD996XT's. The USB to serial adapter I suggested is the one I use. I have never had a problem using that adapter with any software or scanner. I am currently using it with a Windows 11 computer.
My earlier computers had 9 pin serial connectors which mated with the DB9 connectors on the serial; cables which came with the scanners. I have a ton of the serial cables from 396T's, 996T's, 396XT's, and 996XT's. When computers switched to USB ports only, I started using the USB to serial adapters and have been doing so ever since. I have cloned a lot of scanners using 2 serial cables and a null modem adapter.My thoughts here is your adding another connection into the system which really doesn't have to be there. The cable that is linked is more uptodate and compatible with the latest Operating systems.
Actually there is since Windows 10 does recognize the adapter natively as if the computer actually had a serial port and tends to be the preferred setup as it's not laden with the driver issues and bugs of that "USB" cable which just has it's own proprietary serial hardware built in.That's a "serial" based cable not used as much these days. There is no guarantee that a "usb-serial" adaptor would work in this situation.
You can get the same result with one of these
