Hi there.
Last night, while sitting in my van listening to the scanner, it seemed to randomly stop receiving transmissions. My mobile (Baofeng UV-5R) was continuing to receive frequency 412.4625 with CTSS tone 107.2, but my BCT15X was not. I thought perhaps that my antenna got busted, but even when using the antenna provided with the unit, it was not receiving.
Because the unit is only four-ish months old, I got concerned, and frantically started googling what the issue could be. I performed a factory reset, and then reprogrammed in my frequency and settings from memory, and still no avail. I even messed with the squelch settings to see if it would receive - nothing.
What can I do? I'd really like to avoid sending the unit to Uniden as I need the unit here and working ASAP. I will be opening it up and checking for any loose wiring or damage today, but considering how new the unit is, I'm not sure what I'll find. Could really use help/advice here.
Thanks,
Evan
Reaper Roadside
Thanks,
Evan
Reaper Roadside
