OK those links I posted above a few minutes ago are saying that this radio MUST be programmed from the FRONT! The REAR connection is for GPS. The front port must be well hidden cause I cant see it in pictures. Hahahaha sorry for the confusion. So I just need to simply (!) use the cable that comes with scanner, plug the LITTLE end into FRONT of scanner, get a serial (9 pin) to USB adapter and attach it to the OTHER end of cable, then plug that into the USB port on computer! Damn it woulda been EASIER for Uniden to just design this radio with SIMPLER connections!!!Sorry Bob you can get a SERIAL to front connector here is one on ebay.
Uniden DB9 Serial Cable For Scanner Models BC246T, SC230, BCD396T, BR330T, BCD99 | eBay
Uniden DB9 Serial Cable For Scanner Models BC246T, SC230, BCD396T, BR330T, BCD996T - Uniden BWZY1227001. Uniden Scanner DB9 Serial Cable For BC246T, SC230, BCD396T, BR330T, BCD996T. Uniden BWZY1227001.www.ebay.com
So how is the cable that comes with radio different than the cable you suggest above? It seems that they BOTH have the SAME tiny connector on one end and 9 pin serial connector on the other........
