HP-2: Uniden HP-2 Antenna
Bjc123
Montgomery County, Maryland
Hello, I just recently got a HP-2 since my local system is upgrading to a P25 and I was just wondering does anyone like another particular antenna rather than the stock one?
Thanks in advance,
Bradley
fxdscon
¯\_(ツ)_/¯
Thanks in advance,
Bradley
Are you looking for an external antenna or one to attach directly to the scanner the same as the stock one?
hiegtx
Dallas, TX
I have a couple telescopic ones, they're not very expensive and have worked well. Public safety in my area is around 150mhz, which I believe you would set the antenna to rougly 18". https://www.amazon.com/Bingfu-7-Sec...c+antenna&qid=1605036601&s=electronics&sr=1-4
I've had good results with this antenna:
It's a telescopic antenna, as is the one doovenator suggested. It does have a swivel base so that you can adjust the antenna to be vertical. It also has frequency markings on the antenna itself to suggest how much to extend the antenna for a specific frequency range.
It's also available with a BNC connector (you'd use the SMA to BNC adapter that came with your HP-2) as well as an SMA version where you would not need the adapter.
ansky
NJ
I agree with getting a telescoping antenna. I have been using those with every scanner I have owned over the past 30+ years and they always perform the best.
