@mancow If you find that aluminum foil doesn't work (for whatever reason), other materials include:
- aluminum and steel cases (various sizes)
- wire mesh
- wrap around sleeves
- paint
Here's links to these and other types of products that may help:
1) Some metal enclosures:
New improved UNICASE aluminium instrument <a href="/products/186/Enclosures-Panels">enclosures</a> from METCASE are now even quicker to assemble – thanks to redesigned chassis profiles and a new assembly tool (available as an accessory).<br /><br />
www.dpaonthenet.net
2) EMI Shielding & Conductive Adhesives
EMI Shielding Product Category
shielding-solutions.com
3) Instrument plastics Mesh
Instrument Plastics Limited can offer display quality blackened micro-fine mesh for shielding applications.
www.instrumentplastics.co.uk
Developed to give excellent shielding performance offering unequalled light transmission and clarity, with greater performance than ITO coated displays.
US distributor:
www.eastcoastshielding.com
4) Interference-Shielding Wrap-Around Sleeving
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
"Use this shielded sleeving to protect wire and cable from signal distortion caused by nearby equipment and devices. A sewn-in ground wire dissipates any stored charge. It provides good protection against abrasion. Wrap it around wire and cable without disconnecting them; sleeving has a slit along the entire length."
Skip to the section "Heat-Reflective Wrap-Around Sleeving"
5) RFI Shield Can Development Kit (2@ 60 x 80mm, and some shield can clips)
EMI/RFI Shield Can Kit, 0.3mm thickness, Nickel Silver, for manufacturing prototype cans
www.harwin.com
It costs $20. Their size 60x80mm is too small for a 5" touchscreen display: 2.36" x 3.14". Together they're 4.7" x 6.2". Would the two together be enough to see if EMI decreases significantly?
6) General search for EMI/RFI blocking materials:
RFI and EMI - Shielding and Absorbing Materials are in stock at DigiKey. Order Now! RF/IF and RFID ship same day
www.digikey.com
6a) RFI and EMI - Shielding and Absorbing Materials
www.digikey.com
6b) MG Chemicals 842ER-60ML
www.digikey.com
silver epoxy conductive paint:
• Superior EMI shielding
• Ambient and elevated temperature cure
• Excellent chemical and corrosion resistance
• Stable under extreme environmental conditions (100 hours)
• Service Temperature Range -40–150 °C
• Can be applied with a brush, or with manual spray guns (see PDF)
