My396xt will not let me load systems above QK above 10. I know you must press no to go above 10. But it will not go above 10.Any one have any ideas as to what is going on ? FreeScan will load the system but it don't go to high system.
I've seen the same problem here too using FreeScan. I'll wipe my scanner clean before I do an upload and everything seems fine then. If I don't, I usually have some type of odd ball problem.Thanks for the answers. That was my thought also to just start over. I just put a picture program in pc.But when I press the no key it used to make a sound when I tried to go to high system but now it does not.Any way thanks for the help......
yeah that could be the issue for sure!You need to set the QK on the site not the system.
