Uniden SDS100 & SDS200 Color Schemes
bravo14
Polk County FL
I have decide to change color scheme. I did this about 30 mints ago on the 200. I think I like the maroon and gold. I'll wait til daytime see what it looks like. I changed the FUN it won't be a square box.FE1997C9-47A5-4422-A484-C8D4FFA9F718.jpeg
rcool101
Eastern Ohio
Here is mine I came up with. This is a screen shot of proscan. Best way to get the colors to come through.
You need some color on your keys. I've tried many colors but I found Chartreuse shows up best for my eyes. Naturaly it only works on Proscan. On Proscan go to Options/Scanner specific and scroll to Key Color
KWs
Kent , Ohio
If you buy Proscan, it will center the whole codeplug and make everything CAPS or small letters or a mix within seconds. One of the main reasons why I purchased it.
Need some help .... when I click on utilities, update text tags ..
nothing happens . I do not get the update text tags box like you show.
bravo14
Polk County FL
On the top left corner you can get rid of that white box by reversing the color......
Really!? Finally! Thank you!
I'll have to do it once I get my new computer
It had to do with the few last updates on Sentinel I ask about it if they can fix it when UPMan was still around. You'll need to do it for each tab.
rcool101
Eastern Ohio
How do I get rid of the Lines that separate the fields using ProScan?
I don't have any lines in ProScan. The lines are in Sentinel Display Customizer. You don't change anything in ProScan. Just the button color on the Virtual Display
ProScan
Software Provider
Ontario, Calif.
Thanks Bob. Since I love Simple Mode I will live with the lines.
The actual physical scanner will show the lines too.
If you were hinting at a suggestion.
