Correct. The SDS200 and PC Display both show the field dividing lines.
Just put mine in Simple Mode for the 1st time. Yes it indeed has lines. Looks bad.Switched back and will never do that again.
How do you get the Favorites List (Adena P25) to be Center Justified? When I used the Proscan Utilities --> Update Text Tags --> everything id centered but the small text Favorites list.You need some color on your keys. I've tried many colors but I found Chartreuse shows up best for my eyes. Naturaly it only works on Proscan. On Proscan go to Options/Scanner specific and scroll to Key Color
Centered like this.How do you get the Favorites List (Adena P25) to be Center Justified? When I used the Proscan Utilities --> Update Text Tags --> everything id centered but the small text Favorites list.
Jeff
Care to share your file? I dig that one.Scorpion W2 (OCP) camouflage color scheme. A little hard to see because ... wait for it ... it’s camouflaged.
Yea I did that. I got everything centered and I hit save. DL to scanner and I had double of everything. Had to delete the uncentered FLs. I think thats what he askedCentered like this.
When writing to the scanner, Check the option "Erase Favorites Lists On The Scanner" because the scanner thinks that the extra spaces in the Fav name is different Fav List and will treat it as such.
I don't look at my scanner. I look at my second monitor. I run ProScan 24/7. The 200 has everything I want to look at first glance in Yellow. If everything was the same color it would all blend together. You easily get used to detail after the first hour. The 100 might be confusing if you carry it with the smaller screen but I have mine in detail also.I'm just happy that there is a "simple" mode for folks like me who can get easliy confused with the cluster or information that can be available when you first look at the "detail" mode. But since the possible configurations of the detail mode are so extensive, once folks get used to the radio, they can tailor to detail mode to be as detailed or as simple as they like.
Whatever works for you is right.
The scanner will show double favorites because it thinks the names are different and a favorite is being added. Check the option "Erase Favorites Lists On The Scanner" when writing to the scanner to prevent that or delete the favorite afterwards.Yea I did that. I got everything centered and I hit save. DL to scanner and I had double of everything. Had to delete the uncentered FLs. I think thats what he asked
Got it. Makes sense. I will give it a shot. Thanks!Centered like this.
Similar but different:
So that’s where the SDS200 inventory ended up! LOL
What’s the display you have above the stack on the right?
Needs more SDS200 😄Similar but different:
Correct JimD56, A little 7" monitor showing Unitrunker v2 (running off AirSpy SDR). I call it my "horizontal view", so I can see what is happening on the site while the scanner is stopped on another talkgroup.What’s the display you have above the stack on the right?
How do you get that layout and colors with Unitrunker? I tried it about a year ago, and it looked nothing like yours. I run SDRTrunk. Great reception but I am not a fan of the layout, waterfall, etc.Correct JimD56, A little 7" monitor showing Unitrunker v2 (running off AirSpy SDR). I call it my "horizontal view", so I can see what is happening on the site while the scanner is stopped on another talkgroup.
