Uniden wav files player and organizer
rumcajs_tr
Europe, Czech Republic
Is it possible to filter based on CTCSS / DCS ? Most true recordings have some kind of subtone while the recordings without it are mostly noise, so I would like to have possibility to filter by CTCSS/DCS. Thanks.
deim
Universal Scanner Audio Player developer
Saint Petersburg, Russia
NEW release version 2.0.1
new features:
• Added support low resolution displays owing to new design with separate tabs for import files, Filter and export files.
• Added support Drag&Drop folder to program
• Added delete files possibility
• Added double click play possibility
• Added support Whistler au files
• Added load files progress bar
• Now program save last success read files folder and on next start up you may press “Read Files” button at once without “Open Folder”
• Some code optimization and clean up.
If you find some bugs or you have suggestion about my program, please let me know.
Ubbe
Stockholm, Sweden
Hi.
I tested the beta 2.0.1 version and when one file are played and I scroll by clicking on the scroll list it starts to play the file with each click.
I had the list frequency sorted and began at the end of the list and played a file and then scrolled uppwards.
It perhaps are related, that if I mark a file from the end and then scroll upwards in the list and mark all those files and choose to delete them, I sometimes get a crash "wave player have stopped working and are closing down". I suspect that the file are played when scrolling and when deleting it together with all other files it tries to play it but it is then gone and creates an unrecoverable error. The error popup windows seems to indicate a problem with the player. I use Win7 Home.
/Ubbe
Problemhändelsens namn: CLR20r3
Problemsignatur 01: UnidenWavPlayer ver 2.0.1 beta
Problemsignatur 02: 2.0.1.0
Problemsignatur 03: 91858c61
Problemsignatur 04: NAudio
Problemsignatur 05: 1.9.0.0
Problemsignatur 06: cc972473
Problemsignatur 07: 640
Problemsignatur 08: 44
Problemsignatur 09: System.NullReferenceException
OS-version: 6.1.7601.2.1.0.768.3
Språkvariant-ID: 1053
Ytterligare information 1: 0a9e
Ytterligare information 2: 0a9e372d3b4ad19135b953a78882e789
Ytterligare information 3: 0a9e
Ytterligare information 4: 0a9e372d3b4ad19135b953a78882e789
deim
Hi.
/Ubbe
1 bug confirmed.
2 bug still not catch. I can't reproduce this issue. How many files you deleted when the player crash?
1 bug fixed. please download latest version by link in my signature.
Ubbe
Stockholm, Sweden
The number of files where probably 50-200.
It crashed three times and after that I waited to click on the delete files option until the file had played
to the end and that seemed to help.
/Ubbe
Ubbe
Stockholm, Sweden
It crashed a couple of times if it plays a file and if I at the same time click on another file.
So no relation to deleting of files but seems to be when sometimes, not always, click on a file to play when one are already playing.
I have three other programs running that also use sound and wav files so might be a simple incompability problem.
If I wait for a file to finish playing before starting to play a new file it never crashes. That green progress bar that show files being loaded, can that be used to show progress of wav files playing?
The audio level are a bit low when playing files. I have to go from 50% to 100% volume in windows audio output and it's still lower than other apps on 50%. If I play the files in Windows media player it is much louder at 50% volume.
/Ubbe
Xplorer00
Whistler "au" files are not supported in the latest release.
When trying to read the files where Whistler audio is located, it displays "0 supported files found".
Yes, there are 200 audio files in that folder.
deim
Hi, can you send me of your files.
deim
/Ubbe
Hi Ubbe! Thanks for info. I’ll see what i can do with this
Just tried the latest version 2.0.2 and Whistler AU files worked fine. Also like that the file location stays in the configuration when closed. Thank you @deim for your excellent work.
Ubbe
Stockholm, Sweden
Audio are much better now, thanks.
It's a fantastic feeling having both Whistler and Unidens audio files in the same list and being able to directly compare performance and quality of reception. Being able to delete files are a big plus, even if the folders are still there and each one has to be checked if it's empty before I delete them, if I have choosen to save some of the recordings.
edit: I discovered that I can move all files from their folders to the same folder as the player, and it still finds and plays the files regardless if they are in subfolders or not. Whistler resused filenames from some files I have stored since three months back, but normally it increments the filenames but puts them in different folders, so no conflicts if all files are deleted from the SD card and all subfolders can be deleted.
/Ubbe
Ubbe
Stockholm, Sweden
Do you think that you can have a look in the following BCD536 file and see if you can support it?
It's TG9031 (hex2347) that's at 04A2 and 04A3 in the file. I can't remember what UIDs that use that TG, if it's some of the values after the TG but are less important.
Even playing the file in the scanner won't show the TG but that's due to the bug that renaming any of the default nametags will throw the digtial info out the window. It probably has to do with that Uniden has so many nametags in the header, even from other recordings, of the file and those for some reason needs to be the default names for the firmware to be able to find the stored digital info.
/Ubbe
  • No_TG9031_displayed.zip
djeplett
NE Wisconsin
Excellent work, deim. It's working very well for me using SDS100 & Windows 10.
Donation sent! Worth every penny. (Ruble!)
deim
/Ubbe
It is posible to add this info to my parser lib. But i think this fields are wider
TGID offset bytes from 0x4A1 to 0x4A3
UID offset bytes from 0x4A5 to 0x4A7
And it only for Conventional scan mode.
Probably its may be uniden software bug. I tried to search files by this criteria(inputBytes[0x4A2]!=0 or inputBytes[0x4A3] != 0) in my radio rec folder(more than 250K files from sds100 and 436hp) and can't find any files.
I can send you small utility for search this file types in your radio recording archive, if it nessesary.
