Unidens new speaker lineup.
Skypilot----Be a little nicer to Paul...he's doing a great job since he's been with Uniden America Corporation hence why they are still in business even though they have more product lines then GRE. Don't get me wrong...it is sad about GRE closing up in this economy and I hear you loud and clear regarding audio. That is why I don't like handheld scanners period. They lack good audio and eat batteries fast but then again...how can you compare that to a $1,000 plus Motorola Walkie-Talkie. In other words...you can't have your cake and eat it too.
73's
JASII
Memory Capacity
Uniden BC23A External Speaker
Uniden Search Results
The end of October is right around the corner, so maybe we will here more about the availability of these next week. At least I hope so!
sfreiman
Tucson, AZ
I currently use four Uniden speakers for my scanners and shortwave and like them alot. They installed very neatly in my set up as well.
JASII
Memory Capacity
Unidens New Speaker Lineup.
These are now starting to show as "IN STOCK" at some retailers.
newsphotog
Des Moines, IA
Even with an external speaker the audio on Uniden scanners is still too low when used mobile. The power output from the external speaker jack is too low. It is far lower than the 2 watts claimed, I measured it on both of mine and its barely 1 watt with an 8 ohm speaker. Even when used with a amplified speaker it's still not enough. The ouput power needs to be increased and the audio needs filtering. Scanners just have a cheap sound to them. You can hook any speaker you want to it and it will still sound bad. Perhaps someday all my complaining will reach someone who actually gives a crap but so far that hasn't happened.
Honest question... are you pre-deaf? I have Motorola HSN4039 speakers in my Jeep and if my scanner is turned up anymore than 1/4 of the way on the volume knob, it's way too loud. Saying that the Unidens don't put out enough from the jack is bunk.
tomroot
Genesee County, MI
I would say that there is a very good chance that I will get one of these. I sort of wish the AUTO POWER OFF could be disabled. I certainly do like the 90 degree plug. I would sort of like to have been able to detach the cord, but that is no big geal at all. I actually think it might be nice to have a Uniden speaker to match the Uniden Home Patrol scanner.
I guess I'm naive :-( ....With the AUTO POWER OFF feature, do I have to keep running back into the radio room every 25 seconds to turn the speaker back on? The single frequency I monitor with my BC125AT is often silent for 30-45 minutes, when there's a new transmission, and the speaker is OFF, how do I hear it? I don't understand this? What point am I missing?
davidmc36
South East Ontario
If it is like some FM transmitters that I tried out it turns itself back on when it gets an audio signal but you end up missing the first second or two of the transmission. Very annoying. The only FM transmitter that I ever found with audio that was any good had this feature and I took it back without even leaving the parking lot.
Dewey
David described it perfectly... just think of it not as a power off, but more of a "sleep" mode. Audio to the speaker will automagically wake it up, but again as David descibed, there is a noticable chop at the beginning of waking up that is quite annoying to a lot of folks.
tomroot
Genesee County, MI
UPMan,
Thank you very much for the advance information on the Uniden Speakers. Will these be like the Radio Shack Amplified Speaker with the Auto power save circuitry where the speaker automatically powers off to save energy when it receives no audio signal for 25 seconds? I actually don't care for that, so I am hoping that the Uniden BC23A DOES NOT have that feature!
Also, will it has a red LED to show when the speaker is receiving power and/or signal? I do like that feature, but I suppose I could live without it.
Also, will the speaker cable disconnect from the speaker end, just like the Radio Shack, or is it permanently wired to that?
(1) Does anyone know how to castrate the BC23A so it won't shut itself off every 25 seconds? I monitor a single frequency 24/7, and this frequency is often inactive for 30-45 minute time segments! I need a BC23A to stay on 24/7!
(2) Does anyone know of an alternate 3"-4" 32 ohm BC125AT-suitable speaker? ....one that is either non-amplified, or amplified with a definite on/off switch?
Thank you :)
Wow--awesome set-up my friend. This photo should be submitted to a magazine dedicated to our hobby.
Have a great holiday.
Bob
Araxen
La Salle, IL
What does it use for power? I have a Homepatrol-1 will this work with it?
How is the sound quality on this speaker?
tomroot
Genesee County, MI
Thanks guys :) ....I was just hoping against hope that some really techie fellow had figgered out an easy-fix for this sad disease :) ....T
tomroot
Genesee County, MI
And I'd surely like to meet the engineer who thought that this feature was as a good idea :)
Sydney472
Talking Rock, GA
Anybody tried the New Uniden BC23A External Amplified Speaker??
just got this?? do i need some special part from RS to make this work? Bought it from Amazon for $31.00 and plugged it up to a Cig Plug and got power and plugged the other end into HP (speaker/headphone labeled jack) and get nothing --
now I'm wondering if I need a special jack/ adapter from RS. I read the posts above and I'm not sure. thanks for any help...
SkiBob
Out Yonder, GA
I'm not sure if the speaker itself has a volume, but make sure the volume is up on the scanner. This is often something that is forgotten.
Troubleshoot by plugging the speaker into an iPod, phone etc. to see if it works that way.
Just some thoughts.
Happy Holidays
JASII
Memory Capacity
Sydney472,
I you look through some previous posts in this thread, it looks like it is a stereo plug, thus you should not need any sort of adapter to use this with the Home Patrol HP-1.
Jim
"The three speakers are BC7:7-Watt power handling; BC15: 15-Watts; BC20: 20-Watts; BC23A: 15-Watt power handling, 8-watt internal amplifier. All three have stereo plugs, so they are suitable for use with scanner headphone outputs or CB/Scanner/etc mono outputs......Thank you very much for the advance information on the Uniden Speakers. Will these be like the Radio Shack Amplified Speaker with the Auto power save circuitry where the speaker automatically powers off to save energy when it receives no audio signal for 25 seconds? I actually don't care for that, so I am hoping that the Uniden BC23A DOES NOT have that feature!.....Also, will it has a red LED to show when the speaker is receiving power and/or signal? I do like that feature, but I suppose I could live without it.....Also, will the speaker cable disconnect from the speaker end, just like the Radio Shack, or is it permanently wired to that.....Thank you for the details. Is the plug straight or 90 degree right angle?.....90 degrees. Cord is about 12 ft long. Signal is wired tip and base only (ring is unconnected)."
