UniTrunker input issue
Llwellyn
Brooklyn, Maryland
I'm probably just being dense, but I seem to be having an issue with UniTrunker (18th beta). I cannot type anything into any input boxes when they are highlighted... the only one that works is the Label field. I can't manually insert any record into any screen because I cannot enter group ID's; typing into pretty much any other field other than the "Label" field does nothing. I can't easily "F"ind records, because I can't type into the non-label fields.
I'm hoping this is something I'm doing wrong, like missing a keypress first before trying to type...
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Try backspacing after you hit F for Find, etc. The fields are filled with blanks that have to be deleted before you can enter anything.
Llwellyn
Brooklyn, Maryland
Thanks, that did the trick! I tried backspace, but must not have pushed it enough times in a row... without the cursor I couldn't see that it was starting at the end of all of the fields.
Jay911
It's one of the VERY few things I can find to gripe about with UT. Hopefully it won't be an issue with the new windowed version. :)
JoeyC
Senior Member
San Diego, CA
Agreed! I find it very annoying that you have to backspace numerous times before typing anything. Hopefully this is something that can be fixed in a future version.
kd5dga
Killeen,Texas
I found that out last night by accident.
I was not pleased but finally releaved when I was able to put my data in.
