My local public safety SmartZone trunked system has been giving me fits because it keeps changing the control channel on me. I am using a BCT15X to dump control channel data to Unitrunker and I thought the scanner is required to HOLD on the control channel.
While testing the delay problem I discovered that as long as the scanner is not stopped on a talkgroup it continues to pump out the control channel data. So my advice is to disable all groups on that particular system, make sure the scanner is in SCAN mode so it doesn't stop on random unprogrammed talkgroups, and let it scan. It should dump data to Unitrunker with no interruptions even if the control channel changes.
