Unitrunker & Type 1 groups
nosoup4u
High Bridge, NJ
I just started watching Type IIi system, and although I specified the fleet map, I still see the type 1 groups listed as type 2. Is this normal?
Probably not. Try this ... unplug the discriminator tap cable ... wait for the "no signal" message to appear (about 8 seconds) ... plug the cable back in.
You should see your Type I group ids.
nosoup4u
High Bridge, NJ
That didn't help. I also deleted all the Moto* files and started again from scratch....same problem.
I also tried the last version of Unitrunker and I had the same results there.
Normally I can type in a fleetmap and hit "Apply" ... starts right away.
Questions: Which system? What fleetmap are you using? Can you post the SYS and FLT files?
Pap
Pittsburgh,Pa.
Rich !
Where can I find The proper letters for the Type I & IIi size codes ? Also what is the proper letter for type II Blocks ?.
Pap
nosoup4u
High Bridge, NJ
This is the NJ Transit North Trunk System. I don't have a .FLT file, but I see the fleetmaps defined in the .SYS file. I attached that one.
ve3tej
London, Ontario
I have also had problems to. I have changed the fleetmap and there is no difference. This is an 800 Mhz system 223F
I have a couple of commerical radios programed up and have the fleetmap correct in them.
I am probally just missing one little thing. Has anyone been able to get the London Ontario fire department to monitor properly.
