Updating Broadcastify Pi Image
IcomIcR20
I am also running into some issues with the new image. I am trying to get Trunk-recorder running on the new image so that I can use two Airspy SDRs instead of one. When performing some preliminary testing with the same config.json file that worked correctly with the previous image, I immediately received some error messages when attempting to start Trunk-recorder.
At least part of the issue seemed to be that the trunk recorder folder is named "tr," rather than the expected "trunk-recorder." After changing that, I get the following message:
Starting trunk-recorder...
â trunk-recorder.service - BCFY Trunk Recorder Service
Loaded: loaded (/etc/systemd/system/trunk-recorder.service; disabled; preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2024-12-25 19:11:44 CST; 2s ago
Process: 2856 ExecStart=/bin/sh -c /home/pi/bcfy/trunk-recorder/recorder --config=/home/pi/bcfy/configs/trunk-recorder/config.json >> /home/pi/bcfy/logs/trunk-recorder.log 2>&1 (code=exited, status=127)
Main PID: 2856 (code=exited, status=127)
CPU: 5ms
Dec 25 19:11:44 bcfy-89de68a0 systemd[1]: trunk-recorder.service: Main process exited, code=exited, status=127/n/a
Dec 25 19:11:44 bcfy-89de68a0 systemd[1]: trunk-recorder.service: Failed with result 'exit-code'.
Press [Enter] to return to the main menu...
The Trunk-recorder log file states:
/bin/sh: 1: /home/pi/bcfy/trunk-recorder/recorder: not found
However, that file does exist at that location.
Like I said, this is a fresh, otherwise untouched install. Any words of wisdom regarding how to proceed would be much appreciated as I am not super knowledgeable about such things.
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
Can you post your config.json so I can have a look? Remove any API keys from it.
I think I know what the problem is - I might need to update the service definition. I'll get it fixed after the new year and I'll update this thread.
flippinfleck
worcester county
For starters, after writing the image I am unable to update due to a lack of free space.
Perhaps the documentation should include something about expanding to utilize the whole SD?
IcomIcR20
I tested a few different variations, but this is one basic config.json that works with the previous image version but does not work with v3.0:
JSON:
    "ver": 2,
    "sources": [{
        "center": 852556250.0,
        "rate": 3000000,
        "error": -167,
        "lnaGain": 15,
                "mixGain": 15,
                "ifGain": 7,
        "digitalLevels": 4,
        "digitalRecorders": 4,
        "driver": "osmosdr",
        "device": "airspy=0x10A862DC351E2463"
        "center": 858900000.0,
        "rate": 3000000,
        "error": -300,
        "lnaGain": 15,
                "mixGain": 15,
                "ifGain": 7,
        "digitalLevels": 4,
        "device": "airspy=0x10A862DC346A2263"
    "systems": [{
        "control_channels": [859787500],
        "type": "p25",
        "shortName": "VIPER CLEM",
        "modulation": "qpsk"
IcomIcR20
I ran into the same thing. You can free up the remaining space on your SD card by: sudo raspi-config > Advanced Settings > Expand File System > Reboot.
