Updating Broadcastify Pi Image
IcomIcR20
I am also running into some issues with the new image. I am trying to get Trunk-recorder running on the new image so that I can use two Airspy SDRs instead of one. When performing some preliminary testing with the same config.json file that worked correctly with the previous image, I immediately received some error messages when attempting to start Trunk-recorder.
At least part of the issue seemed to be that the trunk recorder folder is named "tr," rather than the expected "trunk-recorder." After changing that, I get the following message:
Starting trunk-recorder...
â trunk-recorder.service - BCFY Trunk Recorder Service
Loaded: loaded (/etc/systemd/system/trunk-recorder.service; disabled; preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2024-12-25 19:11:44 CST; 2s ago
Process: 2856 ExecStart=/bin/sh -c /home/pi/bcfy/trunk-recorder/recorder --config=/home/pi/bcfy/configs/trunk-recorder/config.json >> /home/pi/bcfy/logs/trunk-recorder.log 2>&1 (code=exited, status=127)
Main PID: 2856 (code=exited, status=127)
CPU: 5ms
Dec 25 19:11:44 bcfy-89de68a0 systemd[1]: trunk-recorder.service: Main process exited, code=exited, status=127/n/a
Dec 25 19:11:44 bcfy-89de68a0 systemd[1]: trunk-recorder.service: Failed with result 'exit-code'.
Press [Enter] to return to the main menu...
The Trunk-recorder log file states:
/bin/sh: 1: /home/pi/bcfy/trunk-recorder/recorder: not found
However, that file does exist at that location.
Like I said, this is a fresh, otherwise untouched install. Any words of wisdom regarding how to proceed would be much appreciated as I am not super knowledgeable about such things.
blantonl
Founder and CEO
Dallas, TX
Please continue here. I'll take all feedback on the image here and incorporate into any changes to the image that might be necessary.
blantonl
Founder and CEO
Dallas, TX
Can you post your config.json so I can have a look? Remove any API keys from it.
I think I know what the problem is - I might need to update the service definition. I'll get it fixed after the new year and I'll update this thread.
flippinfleck
worcester county
For starters, after writing the image I am unable to update due to a lack of free space.
Perhaps the documentation should include something about expanding to utilize the whole SD?
IcomIcR20
I tested a few different variations, but this is one basic config.json that works with the previous image version but does not work with v3.0:
JSON:
    "ver": 2,
    "sources": [{
        "center": 852556250.0,
        "rate": 3000000,
        "error": -167,
        "lnaGain": 15,
                "mixGain": 15,
                "ifGain": 7,
        "digitalLevels": 4,
        "digitalRecorders": 4,
        "driver": "osmosdr",
        "device": "airspy=0x10A862DC351E2463"
        "center": 858900000.0,
        "rate": 3000000,
        "error": -300,
        "lnaGain": 15,
                "mixGain": 15,
                "ifGain": 7,
        "digitalLevels": 4,
        "device": "airspy=0x10A862DC346A2263"
    "systems": [{
        "control_channels": [859787500],
        "type": "p25",
        "shortName": "VIPER CLEM",
        "modulation": "qpsk"
IcomIcR20
I ran into the same thing. You can free up the remaining space on your SD card by: sudo raspi-config > Advanced Settings > Expand File System > Reboot.
blantonl
Founder and CEO
Dallas, TX
I am aware of that. As noted, others may not be so it should be in the documentation.
It was supposed to automatically do this on first boot. I’ll find out why it isn’t.
what other questions, concerns, or issues do you have?
blantonl
Founder and CEO
Dallas, TX
JSON:
    "ver": 2,
    "sources": [{
        "rate": 3000000,
        "error": -167,
        "lnaGain": 15,
                "mixGain": 15,
                "ifGain": 7,
        "digitalLevels": 4,
        "rate": 3000000,
        "error": -300,
        "lnaGain": 15,
                "mixGain": 15,
                "ifGain": 7,
        "digitalLevels": 4,
    "systems": [{
        "type": "p25",
I would try opening a terminal, changing directory to /home/pi/bcfy/configs/trunk-recorder and just type "trunk-recorder" to see if it starts.
I think the problem is the service creation which needs to be fixed by me. I should have a new image rolled out next week to fix some of these issues.
blantonl
Founder and CEO
Dallas, TX
I've released an update to the image:
Change Log:
  • Fixed filesystem auto-expand for the image. Image now expands to use your entire SD card correctly upon first boot
  • Fixed trunked recorder auto-start service
Enjoy!
I am open to any enhancement ideas folks have for this image, including more details about SDRPlay support, and any other software, scripts, templates, etc you'd like to see for the image.
DC31
Massachusetts
Lindsay, I am a fairly accomplished Raspberry pi user. Started with the pi1 in 2013 streaming to BCFY. Just today I downloaded the new image to give it a whirl On my pi5. Where did I get stuck? It took me close to half an hour to find the login password! Actually, I gave up and handed the iPad to my wife who found it in the “Advanced” section of the instructions. It needs to be included in item
7: When the flash has completed, insert the SD card into your Raspberry Pi, Power On, and follow the configuration sections below. When you first boot the image, the raspberry pi will reboot 3 or more times to complete the initialization process.
you can’t Get past the “power on“ step without the password.
blantonl
Founder and CEO
Dallas, TX
I'm not sure what you mean by "can't get past the 'power on'" step without the password.
Where in the power on process are you getting prompted for a password? The image is designed to open directly to the window desktop without logging on or requiring any password etc.
Did you change the username on the image? How did you flash the image? Walk me through your exact process, from OS, to software used, etc.
DC31
Massachusetts
Ah, I think I see the hiccup. I flashed the card and then VNC’d in without hooking up any monitor or keyboard. It was the vnc log in that needed the password.
