US Postal Service 408.3375
w2lie
New York DB Admin
Long Island, NY
I'm picking up the US Postal Service on 408.3375 which is currently in the RRDB as P25 NAC 293
Seems they are now DMR, CC01. Picking up TG3 right now discussing mail to Brooklyn and Queens.
Pretty active for 11:30pm at night.
It may be time to adjust that frequency in the database if we can start to confirm who is using TG3 and if there are any other groups on that frequency.
Sounds like what you are hearing is a USPS sorting facility, many of them do use DMR. I just identified one in the Raleigh/Durham area and have heard others in NC. However, what is listed in the database is the USPS Postal Inspectors which usually use P25. If you notice the database lists it as an emergency repeater, it's not a big stretch to assume it isn't used often and wouldn't interfere with the sorting facility.
Remington12G
GØT AES?
Here in Lexington our sorting facility uses DMR, Mostly 1 talk group, and both slots. One for Dock's & Trucks, and another for actually sorting.
ecps92
Taxachusetts
While the USPS Postal Inspectors are P25, which is what is listed in the DB
The Sorting and Distribution sections seem to love DMR and at times have been allocated
the same frequency [not the Primary PIS channels] as what PIS has in P25
Good find, now to narrowdown what site and have it added, but make sure the PIS info is still kept
as they do have it in their radios.
Just noticed N1GAW basically said the same...
n2nov
Staten Island, NYC
The USPS was sold Moto 6550 DMR radios about seven years ago. Many locations used them as conventional NFM radios. It looks like some radio savvy person in the USPS or a consultant is reprogramming radios one location at a time.
Remington12G
GØT AES?
To add to this, you will probably hear them more at night than during day. Regular radio traffic in Lexington starts here around 20:00 and ends around 02:00 next morning. Shift change also changes at 23:00 here so more radio checks are common with the control facility calling admins & line supervisors. It seems every year more DMR is used in the federal band for agencies here in Lexington, most of the time it's not FBI or DEA but the VA hospitals or census bureau.
Analogrules
Are there any active USPS freqs in the NYC area that still use analog FM mode?
n2nov
Staten Island, NYC
From the NYC Federal Database page:
Frequency License Type Tone Alpha Tag Description Mode Tag
406.33750 RM482 NACUSPS RED Inspector Red Net P25 Federal
407.13750 RM482 NACUSPS GREEN Inspector Green Net P25 Federal
407.72500 RM482 NACUSPS WHITE Inspector White Net P25 Federal
407.77500 RM482 NACUSPS BLUE Inspector Blue Net P25 Federal
409.93750 RM482 NACUSPS BLACK Inspector Black Net P25 Federal
408.33750 RM293 NACUSPS EMRG Inspector Emergency Repeater P25 Federal
414.76250 M293 NACUSPS SOD Inspector Special Operations P25 Federal
415.05000 M293 NACUSPS TAC Inspector Tactical P25 Federal
414.75000 M482 NACUSPS BASE Inspector Base P25 Federal
414.75000 M483 NACUSPS ABLE Inspector Able P25 Federal
414.75000 M484 NACUSPS BAKER Inspector Baker P25 Federal
414.75000 M485 NACUSPS CHARLIE Inspector Charlie P25 Federal
414.75000 M486 NACUSPS DELTA Inspector Delta P25 Federal
414.75000 M487 NACUSPS ECHO Inspector Echo P25 Federal
414.75000 M488 NACUSPS FOXTROT Inspector Foxtrot P25 Federal
414.36250 MCSQUSPS I/O Inspector Interop FMN Federal
416.22500 M82.5 PLInspectors Postal Inspectors FMN Federal
163.37500 M065 DPLTruck Ops Mn Truck Operations-Manhattan FMN Federal
166.37500 M065 DPLVMF NY Manhattan Vehicle Maintenance Facility FMN Federal
409.35000 RM023 DPLMorgan Ops Morgan Mail Operations FMN Federal
410.15000 RM343 DPLMorgan Maint Morgan Maintenance Department FMN Federal
407.17500 RM179.9 PLVMF SI Staten Island Vehicle Maintenance Facility FMN Federal
409.10000 RM179.9 PLMaint - SI Staten Island Maintenance Department FMN Federal
164.33750 M251 DPLUSPSBrooklyn Brooklyn Control FMN Federal
407.65000 RM110.9 PLUSPSFlushng1 Flushing Control 1 FMN Federal
409.02500 RM110.9 PLUSPSFlushng2 Flushing/Nassau Control 2 FMN Federal
169.11250 RM110.9 PLUSPS Carrier Carriers FMN Federal
409.52500 RM110.9 PLTruck Ops Qn Flushing Truck Operations FMN Federal
pstephen2
I've programmed all these NYC USPS frequencies for a while now but I never hear anything, even though I'm right in Manhattan and have DMR capability. Sometimes, rarely, I heard a very short "chirping" noise on the Postal Inspection frequency, which I'm assuming is some sort of encryption. Not sure what I'm doing wrong that I never hear trucks, carriers, etc.
ecps92
Taxachusetts
Postal Carriers have no radios.
Radio use is [In My Experience]
Postal Inspectors, Postal Police, Transportation Ops and Sorting Facilities
ScubaJungle
West Central Florida
I wonder if they are also encrypting in addition to programming them as DMR rather than conventional? Because by me, there is a frequency that I get DMR Basic Privacy encryption, which I believe is USPS. I can't really confirm though since it is encrypted.
ecps92
Taxachusetts
Actually confirmation is easy, if you know the potential target.
Go near-by, listen to the input and output - enable ATT on your scanner as well as remove the antenna.
If you still get it full strength, you have 90% confirmed, outside of it having ENC
ScubaJungle
Good point, there are three postal facilities near me, so I need to go try that. The only problem is the transmissions are very sparse and sometimes late at night.
Remington12G
GØT AES?
Most facility operations here in Lexington, KY start around 22:00 on the radios. I always go have a nice dinner at the waffle house next door then wait for the chatter to start. Most of the time it is the same ole admin & sorting but they use clear operations here.
