Using DSD-FME to Decode Encrypted DMR Samples
Digonding
If you want to learn how to decode encrypted samples with DSD-FME (knowing the encryption key), there are a whole range of encrypted samples here:
with a list of commands to use here:
./dsd-fme for linux
or
dsd-fme.exe for windows
Code:
128-bit key : 373374ABE8E9D13AA90900B9A3101664
256-bit key : 3AF8C96E21BEFDE927EE1D03DF53CFA701516B0642AC7B38643549E2BE79840E
Use DSD-FME Build Version: AW 2025-210-geb76ea2
TYT Enhanced Privacy (AES-128) :
./dsd-fme -Z -i TYT-EP.wav -5 '373374ABE8E9D13A A90900B9A3101664'
TYT Advanced Privacy (PC4) 128 :
./dsd-fme -Z -i PC4-128.wav -! '373374ABE8E9D13A A90900B9A3101664'
TYT Advanced Privacy (PC4) 256 :
./dsd-fme -Z -i PC4-256.wav -! '3AF8C96E21BEFDE9 27EE1D03DF53CFA7 01516B0642AC7B38 643549E2BE79840E'
Retevis Advanced Privacy (RC2) 128 :
./dsd-fme -Z -i RC2-128.wav -@ '373374ABE8E9D13A A90900B9A3101664'
Retevis Advanced Privacy (RC2) 256 :
./dsd-fme -Z -i RC2-256.wav -@ '3AF8C96E21BEFDE9 27EE1D03DF53CFA7 01516B0642AC7B38 643549E2BE79840E'
Baofeng Advanced Privacy PC5-128 :
./dsd-fme -Z -i PC5-128.wav -+ '373374ABE8E9D13A A90900B9A3101664'
Baofeng Advanced Privacy PC5-256 :
./dsd-fme -Z -i PC5-256.wav -+ '3AF8C96E21BEFDE9 27EE1D03DF53CFA7 01516B0642AC7B38 643549E2BE79840E'
Motorola Basic Privacy Key :
./dsd-fme -Z -i MOTO-BP.wav -4 -b 100
RC4-40:
./dsd-fme -Z -i RC4-40.wav -1 373374ABE8
AES-128:
./dsd-fme -Z -i AES-128.wav -H '373374ABE8E9D13A A90900B9A3101664'
AES-256:
./dsd-fme -Z -i AES-256.wav -H '3AF8C96E21BEFDE9 27EE1D03DF53CFA7 01516B0642AC7B38 643549E2BE79840E'
hey
Lewes, Delaware
The only thing that’s missing on that website is
p25keyfinder
Digonding
Do you have any P25 DES-OFB samples with known key?
Be careful with the AI, it says anything about subjects it doesn't know. The AI will tell you that it is possible to find a DES key but it knows nothing about it.
It takes about 14 months to find a DES P25 key with an RTX 5090 graphics card. This will cost you thousands of dollars in electricity and when you find the key it will no longer be of any use to you because it will have changed a long time ago, because the DES P25 keys are updated with OTAR (On the air rekeying) :
Digonding
I was able to find the time of someone who created an AI program to find a 40-bit key, it takes him 16 minutes with an RTX 4090
On modern CUDA RTX cores, the computation varies between 16 and 90 minutes depending on the card, at speeds of 400 to 900 Mkey/s in brute force... 16 minutes on a RTX4090
For a 56-bit key you have to multiply this time by 65536.
That's 1,048,576 minutes (16*65536) or 728 days !!
RRR
OFFLINE
USA
Ok, say that is true... Doubt it, but ok.. But why y'all keep talking about it? 🤦‍♂️
Digonding
Simply because since AI is accessible to everyone, many non-programmers, who know nothing about it, all want to make a password cracking software for this or that digital system and they all ask for silence frames.
Simply because AI requires silent frames to make the software.
So we might as well explain what it is to these people. They won't understand anything, but they will be able to copy and paste my explanation into their AI, which will then be able to explain the reality to them.
It's not only here that these people are asking for silence frames, everywhere, on all forums that talk about radio communications...
  • Like
Reactions: hey
jets1961
Or it could happen in 10 minutes 8 day 78 day or 365 days, it all depends on the key. Pretty sure they don't OTA DES keys either, maybe AES 256 keys. So...
iscottybotty
Birmingham, UK
LOL.
hey
Lewes, Delaware
I would like to get a hold of Awit Team I have some questions on somethings and also hopefully they can update the P25 keyFinder 🤣🤣🙏
MTL_Emergencies
Member++
Quebec, Canada
Guys stop embarrassing yourselves.
Many of you don't know how the algorithms work and you can't just multiply a required time by 65536 just because of the 16 bits difference between DES and RC4. Many factors are in consideration such as memory access etc. and we all know RC4 is memory limiting hence the limited speeds.
I think we can close the thread.
iscottybotty
Birmingham, UK
What do you want to know, it's not difficult. I think your biggest downfall is the code from Awit's Team.
Razorback55
For my part I don't think there is a problem, no one has given any code or software to decrypt anything. it's just people discussing their understanding of AI and encryption.
I don't think it's worth going into censorship just for words and ideas.
Even with the best AI, if you give it the content of this topic it won't be able to do anything with it. It's just ideas.
One says it's too slow, the other says no it's not too slow. One says it's not possible, the other says it's possible I do it every morning at breakfast...
  • Like
Reactions: hey
gary123
To sum up using AI for coding. It has been my experience that AI is good at regurgitating code that it has located from other sources (including Git). AI is useless for creating new code or creating code chunks that require original thought.
I have seen tons of posts all over the net asking for a way to ask AI to generate code to do something. In almost every case AI generates valid code chunks but they are not tied together in a coherent or functional package. This is not to say AI is useless but it does focus on the fact AI is not a coder its more like a dictionary. HMM a 'large language model' does descibe its output very well.
