Got my TRX1 this past week from ScannerMaster (downloaded the PDF manual and EZ Scan PC app beforehand to "prep" myself). Since I've been used to Unidens (BCD396XT is my "retired" unit), I had some "learning curves" to work on. For the most part, working the TRX 1 has been good, thanks to the app. Two questions I have with programming:
1). Is there a very quick and easy way to erase and/or transfer scanlist objects?
I believe the easiest way to erase (remove) any/all objects from a given scanlist in the PC software would be to click on the "Scanlist" tab, select the scanlist in question, and remove or delete the objects you no longer want.
In terms of transfer - I assume you mean like move all objects in scanlist 10 to scanlist 20. If so, there isn't anything like a "rename" option; you just need to select the objects to "move", and update them. Again, the best option might be using the "Scanlists" tab - you can select that items in a given scanlist and reassign any/all of them to an a new (or additional) scanlist.
2). How can I use the PC app to set up new scan sets (up to 20 possible) and add more scanlists?
Not sure I understand this question. I don't use scan sets very often. However, I believe scansets are simply additional filters and/or ways to group objects regardless of which scanlist(s) they belong to. I think for best performance, you need to have all scanlists enabled and then you go to the Scan Sets panel on the Advanced Features tab of the PC software. There, you create "scan sets" (give them names) and then assign the scanlists of interest to any given scan set.
