Baofeng UV-82C Reverse Function/Scan Keypad
HalCassidy
When you push and hold the SCN key, the radio enters scan mode. However, if you push briefly and don't hold, it enters Reverse mode with R displaying. Not sure what it means when in reverse mode and if it interferes with normal usage. Is there a way to turn it off and still preserve scanning?
nd5y
Wichita Falls, TX
Reverse mode swaps the transmit and receive frequencies so you can monitor a repeater input.
It only works if you are on a memory channel programmed with with separate transmit and receive frequencies or in frequency mode with the offset and shift direction set. If not then it just displays the R and as far as I can tell nothing happens. There is no way to disable it.
HalCassidy
Thanks for the replay. Since most usage other than simplex is what you describe it seems like a problem when someone accidently hits scan or hits it briefly thinking they will scan. Too bad it can't be disabled.
