V1.31 G2-G5 Firmware Release
ScanWI
MN & WI DB Admin
Wisconsin
I know this doesn't help you, but after the prep time, I was able to log right in. All I can suggest is check your username and password.
NO user and Password are fine, it works fine if I leave RR offline, so currently it appears anyone can import without having a RR account.
FJB2022
Anyone else having an issue with the new PPS working with windows 10? It won't give me the optiion to read because it's not showing I have the G5 plugged up. I hadn't had any issues prior, I've tried getting it to work on 2 W10 machines with no luck and it's not showing up on Device Manager. Works great on windows 7.
Hit_Factor
Saint Joseph, MI
Anyone else having an issue with the new PPS working with windows 10? It won't give me the option to read because it's not showing I have the G5 plugged up. I hadn't had any issues prior, I've tried getting it to work on 2 W10 machines with no luck and it's not showing up on Device Manager. Works great on windows 7.
Look in the event viewer - system log. There will likely be an event ID associated wit the event.
I bet most of us are using Win10, it's not as simple as saying it's a win10 problem.
IAmSixNine
Dallas, TX
Im running Windows 10 Home version 20H2 no issues with PPS.
I also uninstalled previous versions of PPS after installing the new one.
mpreece
Wyoming
The v1.31 firmware had successfully fixed all my noted problems from v1.30. Analog QCII is working, MDC is working, delay of locking in on a conventional channel when first accessed, no cut out when MDC channels received.
As I noted above, it does appear that the function TG-Monitor is no longer active. Simple workaround.
Also, v1.20 and earlier, the silent scan knob setting would override the individual channel reset settings. Not in this version! So I had to duplicate the individual channels to set for “timeout reset” where previously they were on “auto reset.” So now I have “autoreset” channels for normal scan knob positions, and the “timeout reset” for silent scan knob position use. This enables me to listen in either an active or standby mode, as needed.
Kudos to the Unication team in resolving the many issues I had in v1.30.
TxScanner
I’m trying to update my firmware and it’s asking for a serial number, where do I find that?
tkowalik
Banned
Delete the generic driver and download the driver from the Unication website and see if that works. Mine worked fine on Windows 10 until there was a windows update last month, then the pps wouldn’t recognize the pager. After I downloaded the driver it started working again as normal.
Webodisk
Silent key.
Virginia Beach,VA
Having the same issue, user name password invalid, works on RR but not in PPS ,but I can still import hmm. @Jeff780 I had to download the driver file for it to work properly on my win10 laptop
Firebuff66
CT
Same here, Sounds like a RR issue, a friend who does not have a premium account tried and it logged in and said he didn't have an account. Mine just keeps doing the user name password invalid, but it works fine on here and Broadcastify
TxScanner
I had no problem logging into RR. Just to figure out how problem from yhere
FJB2022
I didn't know there was a driver download, guess I should have looked lol. That fixed the issue with W10. Thanks for the help.
JASII
Memory Capacity
I just upgraded. All is well AND I still have 128 x 8 zones!
N6ML
Those having trouble with RR login; do you have any "funny characters" in your password? i.e. other than letters and numbers? Might be worth trying a simpler password.
TxScanner
Can someone tell me where the serial number is located, so I can update the firmware. Thanks
WX4JCW
Stow, Ohio
heres how you get to radio reference
1st click the orange button
then login
here you go
NOTE: any information you import from RR will append itself to the currently open record so be careful where you import
NJFireD1
NJ
PPS will not accept my username and password for RR. However, I can use the same information and get right into RR premium.
N6ML
See comment #54 - no one has commented if they've tried it yet.
