V1.31 G2-G5 Firmware Release
Hit_Factor
Saint Joseph, MI
Those having trouble with RR login; do you have any "funny characters" in your password? i.e. other than letters and numbers? Might be worth trying a simpler password.
I have a long and very complex password with 'funny characters', it works just fine. This was a pretty good idea for troubleshooting.
N6ML
Unless yours uses every possible funny character that RR allows, that doesn't really tell us anything. There may be just one funny character that needs to be "escaped" (or otherwise handled properly), and it happens that you're not using that one. It's just a guess, but I've seen things like this before.....
Hit_Factor
Saint Joseph, MI
I'll wait while you change your password and test out your idea. ;)
N6ML
I would, except my current password works. The only way to test my idea would be to try changing my password to include every possible character until it stops working. I don't have time for that :p
CcSkyEye
Twin Cities, MN
Well, This update still didn't fix the long tone stored voice bug.
Back to 3.14 15, at least I only upgraded one G5 this time.
mpreece
Wyoming
Just curious, what are the symptoms of the "long tone bug"? Most everything I had problems with was fixed. Mine works ok with a single long tone, but freaks out when preceded by a short two tone. Two different VHF analog conventional frequencies in a normal scan. I have tested repeatedly with my signal generator but can't change frequencies quickly enough to duplicate the over-the-air environment.
When trying to open radioreference import option my PPS crashes any ideas on how to prevent it from crashing? I am running Windows 10 on a fairly new HP netbook, I have attached the error message I get
Hit_Factor
Saint Joseph, MI
Go into the event viewer, system log and get the event ID number. That should help us figure out what the problem is. There are lots of enets logged, so it is probably best to open event viewer, got to the system log, cause the error in PPS, switch to event viewer and find the error.
Several posts above I put in links for repairing .Net framework and Windows update. You could try running those, it won't hurt anything.
ScanWI
MN & WI DB Admin
Wisconsin
Nope, while I did try a simple password, numbers and letters only, I should not have get rid of a complex password just to make this software work. Every other program that imports for RR works just fine with my semi-complex password.
WX4JCW
Stow, Ohio
did you try to install and reinstall? my password is complex with a mix of characters,symbols,upper,lower, and numbers and I have 0 problems logging in, I'm thinking something got borked during install
CcSkyEye
Twin Cities, MN
Mine records 12 less than one second stored voice files on the single long tone. While alerting from that tone it, as you say freaks out or as another member said in another post has a full on seizure.
I spent hours messing with the tone timing and waiting after the last update with no luck.
bob550
Albany County, NY
I too have a mix of upper/lower case, numbers, and symbols and have had no trouble accessing RR. I've done multiple downloads so far, and find this to be a good experience with a simple and easy to manage interface.
lifeson
Hilliard,Ohio
mine is still doing it. i tried uninstalling and reinstall. still no luck.
have you got yours to work?
thanks
danny
