Vertex mobile
nick223
Ottawa Illinois
I have a vertex mobile. Can’t think of the model right now.
But I can transmit and receive on the first channel just fine. I can receive on all the other channels but when I go to transmit on the others it says “self test” any idea?
Any way to read the radio codeplug with software? Maybe the other channels are locked on transmit via the software? Have you checked antenna resonance, coax connectors, power supply voltage, etc.? I’ve seen radios shut down on transmit if there’s enough DC voltage drop and/or high enough mismatch in antenna resonance. The message you’re seeing could be the manufacturers way of preserving the radio if everything isn’t perfect.
MBill
Does the backlighting on display turn on/off as if you turned the radio on/off? I have seen this happen when you do not have enough
current to transmit. As I recall you need at least around 10 amps to transmit if a UHF model. Maybe 15 amps if high power VHF. Or you
may have a problem with the final power amp.
Bill
PS: There is an old post by "VTech" in this column discussing why you could transmit on one or two channels and not others if you to not have
enough amperage.
