Vertex vx-800 going into ham bands?
auxscan
Brooklyn, NY
can a vx-800 450-490 Mhz radio go into the 440 MHZ without the hex?
I've heard a few go into 444.000 but thats as low as it goes anybody with any luck?
auxscan
Brooklyn, NY
the radio goes all the way down to the 438MHz. but only works with the older models. newer models w/ keypads only go a couple MHz down. This works without the Hex. The only thing that sucks is the that theres no mixed between DPL/PL. some ham repeaters are set to a DPL input and PL output. but the only way to do this is to leave decoder CSQ/OFF. if the repeater is output is 441.000/ 100.0 pl and the input is 446.100/ 071 DPL. then on the software you would choose DCS/decorder off/encoder 071.
thats the only way it would work. make sure you set the SQ to 7 so you dont grab all the garbage on simplex.
work at your own risk!!!!
