TRX-1: Very Dissatisfied with my TRX-1
Wackyracer
Setting it in auto mode, have any of you found a way to make this scanner recieve the digital mode w/o already it being set....another words, having the frequency set, then using auto to determine which digital mode it is using?
Doesn't work that way with digital since they added NXDN, if your freq is digital you must set DMODE to digital.
Pennsylvania
In order to receive DC to daylight, sacrifices need to be made. In the case of scanners, selectivity is sacrificed for sensitivity. Also sacrificed is front end filtering.
Not surprised. There is no filtering in these scanners. The PSR-500 are notorious for front end overload on VHF.
Band specific radios will always work better for receiving.
The MD-380 is fine if you only want to listen to VHF or UHF DMR/analogue. No idea what scan speed is like.
Sent from my iPad using Tapatalk
I must be very lucky. My PSR-500 doesn't have VHF front end troubles.
