I was able to make some progress. I switched from only using the Ft Lewis (local) site to using the Cumberland site. I have all the other sites on Avoid. Now it is picking up in ID Scan like it should though it still misses some transmissions.
The Cumberland site has some of the same frequencies as Ft Lewis. In particular they both have 152.5475 which is in fact the current frequency that Ft Lewis is transmitting on. I am sure I am not actually receiving Cumberland since it is too far away and I am showing full strength on the signal meter.
My theory, though unconfirmed, is that the one of the other frequencies programmed in the Ft Lewis site from the database is actually picking up some kind of signal which is stopping the scanner from actually hearing the control channel.
The database has the following for Ft Lewis:
152.5475
151.3475
154.3775
152.6525
159.1500
159.4050
When the only ones that should really be in there are 152.5475 and 159.1500. Those are the only two that should ever be control channels.
I haven't reprogrammed yet with just those two in the Ft Lewis site but at least I have made some progress. It is not a bug in the radio itself but probably an error in the database.
John
152.5475
151.3475
154.3775
152.6525
159.1500
159.4050
John
