Well, I've held on all 6 sites and I get a different SID on the control channel which mostly aligns with what RR says. I hold long enough to see it show up. Sometimes I get a carrier, but no SID, so I figure that is bogus, but if the carrier is always there and the SID blinking I figure it's real. Mind you, I'm just about line of sight for Fork Mt, Apple Orchard although it's a long way away and PW county and my antenna is fairly high, I'm not using a stick off the back of the radio. I don't know if this forum does image codes but here's the direct link to what I see
http://i251.photobucket.com/albums/gg287/DogTi/other/996sid_zps8000c2ea.jpgDave
Dave,
Thanks for your feedback.
There are 2 separate things that need to be done to verify control channel vs voice channel level.
If you hold on the control channel you will see the site specific data/ID, however, you will not hear any voice comms. Although this is a good start, the radio will need to lock on the control channel, which may take a moment depending on the signal level. Once locked on the control channel you will then see the system specific data/ID.
Then the next think you want to do is find an active Talk Group for the site/system you are able to monitor, then hold on that specific talk group. What the S meter/bars carefully and once the voice comms drop, the radio will then drop back to the control channel. If you signal is very strong, you may need to turn on the attenuator or use an antenna on the radio to reduce the signal level a bit.
What I am trying to find out is if all the STARS sites have control channels that are much lower in level than the voice channels, do the control channels equal the voice channels or are the control channels slightly higher in level than the voice channels.
I am seeing a "problem" with the Fairfax site at this moment when the control channel is lower in level than the voice channels. I have to get some other equipment together to compare or get a reasonable idea of how many dB difference the levels are, but for now it is relative as compared to each other using the radio S meter.
The other major issue with STARS and a VHF trunked system is the frequency wave length and marginal or fringe level signals. The nulls for VHF appear to be about 12-18 inches apart. I spent some time in front of my house this evening monitoring the Fairfax STARS control channel. I could hold my 396XT locked on a Talk Group that was not active and if I only moved the radio horizontally between 12-14 inches I would fully drop the control channel. Move the scanner back to the original position, then control channel will reacquire.
So overall not sure the scanner has any specific issues with STARS yet, however, STARS the way some of the site transmit levels are set and the wavelength of VHF for use on a trunk system are all kind of a perfect storm.
I also assume that since VSP as originally on 159 MHx, the reused many of their original antennas and because of the up to 10 MHz difference in control channel vs voice channel frequency, there may be some antenna gain roll off issues that maybe the STARS radio techs have not taken into consideration when balancing out and setting RF levels at the transmitter sites?
Again, I see this time and time again when radio techs "think" they understand what they are doing but fail to see the much larger "system" picture?
