Virtual Audio Cable?
se
Minto, New Brunswick Canada
Hello All.
If I want to decode WEFAX with my SDRplay, do I need to download a virtual ausio cable program, and if so which one is the best to use?
Sheldon.
natedawg1604
Colorado
Hello All.
Sheldon.
SDRPlay does not decode anything, that is handled by a separate program. First, you need to capture your tuner's baseband signal with a program like SDR# or SDRUno, tune to the proper frequency and route the baseband signal to the actual decoder program. Then you need to find a program to decode WEFAX, you may want to start here. I'm not sure if SDRUno supports routing your signal to other programs via TCP (i.e. like FMP24 does).
However, even if you can pipe out your final baseband signal via TCP, the ultimate decoder program must also support TCP routing on the input side, and AFAIK very few programs (DSD+ is one) support this. Most programs seem to only support traditional soundcard inputs. If your chosen WEFAX decoder program doesn't support TCP, then you will need to route the signal via sound card. You can always start with VB-Cable (free version) to route your audio signal in the appropriate manner. If you start needing multiple virtual cables, it may be best to buy Virtual Audio Cable. However, to get started I would just use VB-Cable.
se
HI.
I now have a virtual cable for my SDRplay, but I would like to find a virtual wideband antenna for it now. or a real small indoor antenna.
Sheldon.
majoco
Stirrer
New Zealand
Now that would be something that we all want - a virtual wideband antenna. Let me put my inventor's cap on..... :)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes, however updates for the last version(s) of SkySweeper are still available, for those that have it (and yes, the software direct from the manufacturer is discontinued). Its curious, to be sure, but there it is - I certainly never expected it... Mike
ab5r
I think he was asking about WEFAX from orbiting weather sats. Many people use Wxtoimg software with either a Turnstile of QFH type antenna. Personally, I have used both types and prefer the QFH antenna.
Hope this helps.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Some of these will also work with Satellite generated FAX, if memory serves...Mike
Your_account
.AT
How much other Virtual Audio Cable Software support how much virtual cable?
