WS1040: Volume Knob Issue
BC2001
BCD996P2, BCD536HP, BCD436HP, HP-1&2, BC125AT, BC3
Pineville, KY
So I've had this WS1040 for a little under a year and a half. Lately, I've been noticing a crackling noise when I turn the volume knob up or down. Unfortunately, the scanner is out of warranty. So here is my question:
What steps can I take, if any, to remedy this problem?
Thanks in advance & I hope there is some, because besides this, I haven't had any major problems out of it, and it's been a good scanner since I've had it.
WB9YBM
Try to find an opening on the pot's body (you'll have to open up the radio to get at it) where you can spritz in some tuner cleaner, and rotate the volume knob several times while spritzing. BTW make sure the radio is turned OFF and leave it off until all of the tuner cleaner evaporates.
BC2001
Pineville, KY
Okay, I will try that as soon as I get some, thanks.
Also, this isn't an indication that my scanner is going out or messing up at all is it?
Nasby
Ohio
Its a very common problem caused by build up in the pot. Your scanner isn't going out.
The spritzing suggestion should fix it.
One thing to add, after you apply the lubricant, turn the knob a bunch of times at a fast pace to let the lubricant do its job.
BC2001
Pineville, KY
Thanks, I will do that, I appreciate the additional information.
dispatch235
Central Missouri
Very common problem in those models. I have the older Pro 106 and a newer Pro 651 that both have that issue and really doesn't annoy me much as it seems to have not gotten any worse. I did spray the 106 with some deoxit some time ago and but didn't seem to help much as there didn't seem to be much of a way to spray it into the control. I believe i did get some to work its way down the volume shaft though.
There have been several threads on here in the past about it.
SteveSimpkin
Lancaster, CA
Even without spraying tuner cleaner into it you might find it gets better just by turning it up and down a bunch of times
WB9YBM
[/QUOTE]
I doubt there's anything to worry about. Mechanical stuff will wear out first, and that stuff's replaceable.
Ronaldski
MI DB Admin
Bay City MI
You can really count on I can confidently say most every to be safe, if not all the radios that use that, i.e. pro 106, pro 651 will experience this staticy situation within a week or a few more depending how much the person uses the knob.
BC2001
Pineville, KY
Okay, thanks to everyone for the help, I am just glad it likely isn't anything wrong with my scanner.
