vx-7r charging question
KK4ELO
Smithville, Tennessee
I recently bought a 7r, and it came with a cd-15a rapid charger. I usually put it in the charger over night, but evidently once the stand says charged, the radio burns the battery thoughout the night. Leaving me with a dead battery about midday.
My question is, I have an extra nc-72b wall wart. Can I use the extra wall wart to power the radio for monitoring while charging the battery separately in the rapid charger?
teufler
ST PETERS, MISSOURI
sure you can, though on my vx7, which I have owned since about 2003, I get ac hum in the transmitter while it is pluggeed into the wall. On receive, no problem. UIsually about 2 hours, the change is done.
KK4ELO
I wont be transmitting, only receiving. The battery will be in a separate charger, with no battery in the radio. I need to know if i can plug in and power the radio without a battery in it.
Thanks for the reply.
majoco
Stirrer
New Zealand
I've had a little VX-2 for a good few years now. One of the first things I found was that the supplied charger just wasn't doing the job - it didn't fully charge the battery even though the charge light had gone green. I had a bigger fatter 6volt (nominal???) wall wart so I fitted an adaptor to fit the Yaesu socket - after that it was all good - I have the radio going for three or four hours a day and I charge it when I think of it - say once a week or less! I can't recall the last time it went flat on me.
teufler
ST PETERS, MISSOURI
reference to the vx7, I just tried, leaving the battery off and plugging the wall wart into the radio with out a battery. No problems. So I guess it works.
gewecke
Banned
Illinois
Are you transmitting on your vx-7 while it's in the cd-15a charging stand with the nc72b wall wart? DON'T! The instructions will tell you it's NOT designed to be a power supply capable of enough current to transmit with, receiving is fine however. ;) 73, n9zas
